Rearend moaning in turns + braking.
Old Jan 22, 2004 | 07:29 AM
94BlackBowtie's Avatar
It's just a deep moan - that's the only way I know to explain it.
Don't know what is causing this - but it seems to only happen during a certain few 90° turns while also applying the brakes - and sometimes while just turning 90°.
It is an LS1 rearend in a '94 Camaro.
TIA.
Old Jan 22, 2004 | 07:36 AM
IDOXLR8's Avatar
Could be a bad posi.
Old Jan 22, 2004 | 08:21 AM
Also just a note - I had the cover off just about 3,000 miles ago on it and everything looked pretty good. There was minimal metal on the magnet - nothing much - just very small shavings. All the gearing appeared to be in good shape as well.
Also - there is no rear end "whine" at all - just this eery so often moan. Almost sounds like it could be something with the brakes - but it only happens in sharp turns.
Old Jan 22, 2004 | 08:26 PM
ramairta94's Avatar
Did you put GM limited slip additive back in when you changed the fluid?If not thats probably it.
Old Jan 23, 2004 | 07:24 AM
No I didn't - I just used Mobil1 Synthetic Fluid.
Why/how could not using that additive make it moan intermittently? Just out of curiosity.
Old Jan 23, 2004 | 04:55 PM
ramairta94's Avatar
Its just the clutches making that noise,id say its intermittant because your running syn.Thats probably the best answer i could give you.Ive just seen it a bunch of times over the years.If it doesnt have that gm additive 9/10 it will make that noise.
Old Jan 26, 2004 | 09:38 AM
Thank You.
blac94Z
29
Mar 25, 2015 04:21 PM
ddr698
Jan 31, 2015 10:58 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
ddr698
Jan 9, 2015 10:05 AM
formula79
26
Aug 5, 2002 12:21 PM
