Just bought System!
Old Jan 19, 2004 | 12:12 PM
93Cam's Avatar
Just bought System!
Well the hole home theater sub thing was just not lookin like a good idea, so i bought a bazooka amp and mtx sub. I am gonna bridge the 2 channels to run the full 400watts into the one sub, and i just need a little help on how to set it up.
1) Should i set the filter to low, flat, or high, since its only gonna be powering the sub?
2) How should i set up the crossover, its adjustable from 60-400Hz. I really dont understand the whole crossover thing so could someone explain.
Thanks. Steve
Old Jan 19, 2004 | 12:19 PM
LS1 RULZ's Avatar
1) Since the amp will be used for a subwoofer you need to set the control for low-pass.
2) Set the X-over to 60-80Hz Any higher than that can cause the bass to sound boomy since you are now getting into the lower mid-bass frequencies.
Old Jan 19, 2004 | 08:00 PM
YOUNGGUN96's Avatar
I have a little input for ya. Just because it is a 400 watt amp and you bridge it to your sub, that doesnt meen that your sub is getting 400 watts. Your amp could be making that 400 watts at 1 or 0 ohms and if your sub is a 4 or 2 ohm speaker then it is really only getting about 150 for 4 ohm and maybe,maybe 250 or 300 for 2ohms! just my .02
Old Jan 19, 2004 | 08:55 PM
LS1 RULZ's Avatar
A bridged Pyle amp will probably go into meltdown if you connect it to a 2ohm load.
Old Jan 20, 2004 | 07:12 PM
YOUNGGUN96's Avatar
You got a good point their, I was'nt sure how good of amps pyle made.
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Mar 25, 2015 12:09 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
95chwagon
Feb 28, 2015 12:02 PM
