Pontiac TC cover gasket
Old Dec 22, 2003 | 10:47 PM
whitetrashT/A's Avatar
Is doing a Pontiac timing chain cover gasket (1970 350) as difficult as doing a small block chevy? I've never been able to get those to work without leaking..
Old Dec 22, 2003 | 10:58 PM
talos's Avatar
it can be a real beatch to do it... most of the time to get the best seal u need to lossen the front of the oil pan... thats the best way to get the best fit.
Old Dec 23, 2003 | 10:41 AM
IRONFIST's Avatar
You're going to need to drain the rad a bit, or atleast be prepared for coolant to go everywhere. Since in a Pontiac the timing chain cover has the water pump attached to it. Also, the timing chaing cover is connected to the oil pan from underneath and the intake manifold (with only one bolt).
99TransAmWS6
Mar 22, 2015 11:00 PM
Jazsun
Dec 29, 2014 12:14 PM
Snoman73
Nov 17, 2014 07:22 PM
whuzizname
12
Jul 22, 2002 07:52 PM
