Fuel injector size question inside please...
Old Dec 7, 2003 | 01:42 PM
roguedriver's Avatar
Anyone know if theres some kind of formula or know a round about estimate on what size fuel injectors are needed vs. what kind of flywheel HP your running? Just curious. Hope this is the right forum too. Thanks in advance.
Ken R 95Z
Old Dec 8, 2003 | 09:30 PM
RCF925's Avatar
Go here: https://www.camaroz28.com/calcs/index.shtml
Old Dec 14, 2003 | 03:18 PM
nitropatch's Avatar
i know that the 24lb injectors will hold up to 450hp to the flywheel, so if you have those you should be good to go.
Old Dec 14, 2003 | 07:05 PM
rskrause's Avatar
Moderator
24lb injectors would not be adequate for 450hp unless they were run at very elevated fuel pressure.
Rich Krause
Old Dec 14, 2003 | 09:08 PM
nitropatch's Avatar
Rich Krause
thats just what they support, you have to have the right stuff to get the hp but the will hold it.
Old Dec 15, 2003 | 01:59 PM
A 24# injector, stock or SVO will flow about 25#/HR at stock (3bar/43.5psi) pressure. If you do the math.....
(25 #/HR) X (8 injectors) / (0.45 #/HR/HP BSFC) = 444flywheelHP
And that's at 100% duty cycle. Yes.... a well tuned NA motor can probably see a 0.42 #/HR/HP BSFC, and that would change the HP capability at 100% DC to 476flywheelHP..... but you would be foolish to run the injectors that hard. If you use the general guideline of 80% max DC, you will be limited to 380flywheelHP.
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
nophix
Nov 30, 2014 10:26 PM
Jul 4, 2005 05:00 PM
