Cranking noise
Old Nov 14, 2003 | 11:56 PM
SpecForceZ28's Avatar
Cranking noise
Whenever I am stopped, or going at low speeds(max. 10mph), when I turn the steering wheel, it will make some sort of a cranking noise. What do you think is causing this noise? It is very loud and annoying to deal with
Old Nov 15, 2003 | 11:43 AM
#7's Avatar
Its definitely your rack&pinion. Not to bad of a repair to do. There are 2 kinds of replacement racks.Which one you need depends on if your car has FIRM ride or not. There are codes to tell,not sure what they are.But the parts guy will tell you what code to look for to determine firm or not.
Mine was the firm ride rack,it is cheaper
T.
Old Nov 15, 2003 | 01:46 PM
How much do these run?
Old Nov 15, 2003 | 04:16 PM
terryhensley's Avatar
turn the steering wheel, or stop, feel pop
Whenever I am stopped, or going at low speeds(max. 5 to ? mph), when I turn the steering wheel, it will make some sort of a pop noise. What do you think is causing this noise?
weigh2fast4u
Jun 28, 2015 08:28 PM
blkWidow
Apr 21, 2015 01:56 PM
BigWil
Mar 29, 2015 12:24 PM
Fatdog2
Feb 12, 2015 12:24 PM
squarehead
Nov 21, 2014 08:02 PM
