The beast is out of its cage ... :)
Old Nov 13, 2003 | 12:20 AM
LWM's Avatar
LWM
Smile The beast is out of its cage ... :)
Project 383 just left the dyno at 525 rwhp @ 6,100 rpm and still heading north at a phenomenal rate ...
Steel Callies crank
-31 cc dish SRP forged pistons
Crane 1.5 non self aligning roller rockers
Comp cams 224/236 114lsa
SVO 42# injectors
Super FMU, makes 58psi of fuel pressure at 8 psi of boost at 6,100 rpm
AFR 190cc heads with 58cc chamber to make 8.9 - 9.0:1 compression ratio.
Oliver connecting rods, 5.7"
ARP head studs and bolts
Splayed 4 bolt main caps
S-trim blower, 3.125"/7" pulleys
Stock computer with LT1 editor, set the injector constant to 47# and the cylinder volume to 47.875 cu in. Set idle speed up to 850 rpm.
Runs good, air/fuel ratio is solid at 12:1
Gotta say thanks to the board for all the help in answering my questions along the way ...
LWM
Old Nov 13, 2003 | 04:42 AM
SMOKNZ's Avatar
Crank the boost on that motor, it can handle alot more!!
Bill
Old Nov 13, 2003 | 11:09 AM
MEAN LT1's Avatar
Bill
hehe, yea but will the s-trim be able to put out much more.
Old Nov 13, 2003 | 11:26 AM
rskrause's Avatar
Moderator
Congrats, and best of luck wih the new setup!
Rich Krause
Old Nov 13, 2003 | 07:24 PM
Z97LT1's Avatar
I'd say absolutely. Talk to Jim (INTMD8) or LJ (10secz) about what they did with an s-trim
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
