best clutch for daily driven turbo LT1?
Old Nov 5, 2003 | 09:27 PM
383WS6's Avatar
I'm looking for something that drives similar to the stock clutch but will hold up to over 650RWHP. any ideas?
Old Nov 5, 2003 | 11:07 PM
Chris B's Avatar
I don't think you can get a clutch that drives exactly like stock but will still hold that much power. But for your application I would suggest a mcleod twin disk for sure, with a steel flywheel if you want a little better drivability. I have one with the Al flywheel and drivability is the same as my last kevlar/kevlar normal clutch.
Chris
Old Nov 6, 2003 | 01:53 AM
96 WS6's Avatar
Only choice is the street twin... or a nice auto.
Old Nov 6, 2003 | 05:00 AM
rskrause's Avatar
Moderator
Street Twin is the only viable option, IMHO.
Rich Krause
Old Nov 6, 2003 | 06:27 AM
IDOXLR8's Avatar
As stated above go with the Street Twin. Alot of people go the cheap route with a clutch and end up paying alot more later. Some people will recommend going with a SPEC clutch but everyone I have ever seen usually has some sort of premature failure.
Old Nov 6, 2003 | 05:42 PM
RCF925's Avatar
Another vote for Street Twin, Peddle pressure is not to much more than stock
Old Nov 6, 2003 | 06:42 PM
383WS6's Avatar
is this street twin all or nothing, or does it react somewhat like a stocker? by this i mean is it going to jump as soon as i move my foot an inch or is there some play?
Old Nov 6, 2003 | 07:10 PM
Chris B's Avatar
There is definitely play in it - if you are every in the college station area you can check one out on my car.
It is very easy to drive around in, but it is grabbier than stock. Not nearly as grabby as some of the ceramic or brass puck clutches I have tried.
Chris
Old Nov 6, 2003 | 07:16 PM
wingnut's Avatar
Street Twin!!!
Old Nov 6, 2003 | 07:24 PM
383WS6's Avatar
I'll be in college station when i bring my car to Jordon, but while TSP is going through my tranny i thought i'd go ahead and replace the clutch. you're positive this is the best one for my application. aslo, what do they typically cost?
Old Nov 6, 2003 | 09:03 PM
97TA-WS6-Con's Avatar
Street Twin is the ONLY option.
About $800 - $850 USD. Check Tbyrne.
Old Nov 7, 2003 | 03:57 AM
SMOKNZ's Avatar
And they are rebuildable. Mine has to go back in due to a little grooving in the floating plate. Never had any slipping issues and I was able to cut 1.90 sixty's with it on Nitto drag radials. I noticed the grooving when I was removing the tranny from the engine
Old Nov 11, 2003 | 09:09 AM
Camaro_Guru16NY's Avatar
[QUOTE]Originally posted by aggiez28
[B]street twin
NUFF said. it doesent get any better than this.
Later,
-JOhn
blac94Z
Jan 22, 2015 11:19 PM
cmdeshon
Dec 12, 2014 10:51 PM
JordonMusser
Jun 13, 2003 11:53 AM
JordonMusser
Sep 11, 2002 12:12 AM
simple
Aug 11, 2002 11:56 AM
