Bad PCM?
Old Nov 4, 2003 | 09:31 AM
curtSr's Avatar
Bad PCM?
Hi!
I have a miss in #2 cylinder that I have narrowed down to the pcm. The things that led me here are as follows:
- verified compression in the cylinder
- verified spark at the plug
- swapped injectors
- verified B+ at the injector
- verified the wire harness to the pcm from the injector
- I also verified that the pcm is not grounding the circuit for this injector.
Can this be caused by or fixed by reflashing the pcm with tunercat. Should I just go out and buy another pcm. This is obd1 95 lt1 transplanted into triumph Tr7.
thanks
Curt Sr.
Old Nov 4, 2003 | 10:44 AM
madwolf's Avatar
Sounds like the PCM is faulty. Reflashing will not help. You will need to either get it repaired or get a different one. I don't know of anyone who fixes injector drivers though.
Old Nov 4, 2003 | 10:44 PM
curtSr's Avatar
Thanks for the reply. If I can't find a replacement locally, I will be in touch to get one from you.
Curt Sr
Old Nov 6, 2003 | 10:28 PM
slayer6x6's Avatar
Did you check the grounds for the PCM?
Old Nov 7, 2003 | 11:22 PM
curtSr's Avatar
I will check them again. Is it possible that a poor ground could cause an injector failure that only effects one cylinder? Thanks for the help on this
Old Nov 8, 2003 | 03:24 PM
95 Z/28 LT1's Avatar
Super Moderator
I was wondering if a bad ground would damage the injector driver.
TitoPR221
May 26, 2015 12:20 AM
Zuvell
May 15, 2015 08:18 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Jan 5, 2015 07:14 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
