Help me bring my paint back to life
Old Oct 22, 2003 | 07:47 PM
splinter_cell's Avatar
Okay, about a month ago I bought an 84 Z. The paint is not too bad on it. It looks like the previous owners just let it sit and the sprinklers must have hit the car and there are some really bad water spots. I have clayed the whole car and it made it super smooth but did not really take the water spots out. The windows are a little hazy too. Should I use Meguiars body scrub or 3M Swirl remover to help remove the water spots? Do you think because it is older I should go with 3M?
Old Oct 23, 2003 | 10:43 PM
KillerTA's Avatar
What you probably need to do is have the car buffed with compound, then swirl remover, and then polish. Otherwise it is pretty hard to fix.
Old Oct 26, 2003 | 01:35 AM
PoloGreen 3.4's Avatar
speaking of this, i have the defective paint..the clear coat is pretty much off on the top of my car, and is starting to do the same on the back...what can i do?
Old Oct 26, 2003 | 02:58 PM
KevinSS's Avatar
For the windows you will want to get some Zaino Z-12 Glass Polish to remove the have and water spots on them, it is the only glass product I have ever used that will do this.
On the paint you will most likely not fix the paint in one or two steps, it will take more than that, read on:
The 3M Swirl Mark Remover part number 39009 is very mild, it may not be strong enough to remove or cut down your surface defects.
If you want to do it yourself and come out right the first time you will need to purchase an ORBITAL buffer, one of the very best can be purchased at Lowes, it is the Porter Cable orbital buffer/sander with adjustable speed, model number 7336 cost 109.00. Use the foam pad that comes with the buffer kit. Start with 3M Finesse It II machine compound and then work that into the paint with the buffer until the product thins out, then remove it BEFORE it dries, inspect the surface to see if the paint is getting better, you will then need to wash the foam pad and start on phase two which is doing the entire car with the buffer and foam pad using the 3M Swirl Mark Remover part number 39009 again, work this into the paint until it breaks down from a paste to an oil and remove it BEFORE it dries.
If you want to go one more step for an all out finish, you can add step three which is to buff the car with the foam pad and porter cable using 3M Imperial Hand Glaze and remove while wet.
At this point I like to wash the car as you have put a lot of products on it to remove extra oils and buffer sling. Now you should be able to apply your final finish wax or durable polish that you have selected (Zaino in my case) for extended use.
Old Nov 5, 2003 | 11:49 AM
93stixz's Avatar
My Clear Coat
My Clear coat came off too, my car is also green, maybe green suckd for them... i want a solution other than getting it repainted.
Old Nov 11, 2003 | 01:13 AM
Compstall's Avatar
Bring it on over to my house, I'll hook you up.
Old Nov 11, 2003 | 01:47 AM
Re: My Clear Coat
Well i wrecked my car a while back, and got the whole thing repainted...I knew a guy that was going to compound sand the clear coat off, and then put a few layers back on...said that it you could still see some of the spots, but it would ultimately look much better, and much cheaper than a paint job.
Old Nov 11, 2003 | 02:18 PM
93stixz's Avatar
how did he repaint it with and what was it with, what type of clear coat. Or was it the type of clear coat that a body shop would use. let me know. the problem is getting worse.
Jazsun
Dec 29, 2014 12:14 PM
bernie1951
Dec 10, 2014 10:03 AM
Fastbird93
Jun 30, 2002 05:49 PM
