Clunk under car....
Old Oct 16, 2003 | 04:49 PM
Michael Ozorowsky's Avatar
Clunk under car....
Hey. When I drive around, and am cruising down from 40, I hear a clunk, or maybe a pop from under the car. I am thinking broken tranny mount maybe? This is an automatic, been doing it since I put my transmission back in (Had rebuilt, and put a high stall verter in). Any ideas? Also, FWIW, I have a Spohn Torque arm. Could it be the Torque Arm clunking? Any opinions/experiences are great, thanks.
Old Oct 16, 2003 | 04:51 PM
Slappy3243's Avatar
Does it clunk when you accelerate quickly from a stop? Mine did and It was a broken tranny mount. Easy fix.
-Adam
Old Oct 16, 2003 | 04:54 PM
No, not really. Sometimes if I go over a bump a little too fast it clunks. Will it hurt anything? How much does new mount cost? Should I get a poly mount? How do I know for sure it's the tranny mount broken without replacing first? Thanks.
Old Oct 16, 2003 | 08:55 PM
Black01_Z's Avatar
Isnt your car under factory warranty being an 01, take it to the dealer and tell them there is a noise and you need it fixed. If its still under warranty they will fix for free.
Old Oct 17, 2003 | 04:54 PM
No warranty on modded car. Car IS modded. Suspension is noticeably not stock. Anyone else have any opinions?
Old Oct 17, 2003 | 06:42 PM
Slappy3243's Avatar
Ok, I am not going to remember the exact dollar amounts because I replaced the Tranny mount on my 2000 Firebird about a year ago. Anyway, I believe the part from the dealer was about $50 or so and I did the install myself. To see if it is broken, just go under the car and look at it. Mine had a noticeable tear in it. After I replaced the mount, my car was perfect again, no clunks.
http://www.installuniversity.com
I followed their install instructions even though I had a 6 cylinder. Easy to follow. Look under install documents, then tranmission mount.
-Adam
Old Oct 17, 2003 | 08:09 PM
Ok, should I replace with a poly mount or regular or what? Keep in mind, this is an A4. What is the advantage of a poly mount? THanks.
Old Oct 17, 2003 | 08:14 PM
Slappy3243's Avatar
I have heard mixed results with the poly mount compared to the rubber one. The poly mount will be stronger but it will cause a lot of vibration. Some people say the vibrations get a little better but still more than a stock mount. I would stick with the rubber one.
-Adam
Smokn '94 Z
Mar 25, 2003 09:00 PM
Achilles97
Mar 18, 2003 11:56 PM
SpecForceZ28
Mar 10, 2003 01:28 AM
2MCHPWR
Feb 12, 2003 08:59 PM
