Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Ring and pinion install
Old Oct 12, 2003 | 01:07 PM
lsformula's Avatar
Where is a good shop to have a new gear installed? Anyone had work done at The Ring & Pinion shop in Roseville on Gratiot? They quoted me around 550 for a GM 4:10. Sounded about right.
Old Oct 12, 2003 | 01:27 PM
Dave89IROC's Avatar
get a hold of scott(1bad86z i think) on here, he does them cheaper than that and he used to work for DTS, he did mine in the spring and i have had zero problems
Old Oct 12, 2003 | 02:14 PM
1BAD86Z's Avatar
gear install
NO... that sounds to expensive. a gear, labor with bearings "if needed" would only cost you $400.00 if i did the work. and thats a GM gearset to boot.
Old Oct 12, 2003 | 07:00 PM
lsformula's Avatar
This is the first time I am looking to have a gears installed. The car is an m6 and I thought the 4:10 made sense. Would the gears whine? I have heard they would. Also do you guarantee your work? Thanks for the reply.
Old Oct 12, 2003 | 08:21 PM
1BAD86Z's Avatar
If you have a 6 spped manual than the 4.10 ratio will work out just fine. I warranty my work just like DTS does, 6 months parts and labor.
As for gear wine, I strive to do the best job possible.
given that aftermarket gears WILL at some rpm make noise.
that is why i try to use a GM made ring & pinion set.
Old Oct 12, 2003 | 08:29 PM
lsformula's Avatar
One last question. Do you recalibrate the speedo or am I on my own? If not you, do you know who does? Thanks.
Old Oct 12, 2003 | 08:56 PM
CLOKWRK's Avatar
Scott just recently put 4.10's in mine and they are silent. No whine, zero! He'll do a great job for ya!
Sorry I couldn't make it by today Scott, my wife had other plans for me. LOL How's your ride comin' along? You going to make it to M8? I'll give you a call the end of the week or something, maybe we can follow each other out to Stanton. -Greg
Old Oct 12, 2003 | 09:12 PM
lsformula's Avatar
Where did you get the speedo recalibrated? Thanks for the reply.
Old Oct 13, 2003 | 10:37 AM
CLOKWRK's Avatar
Originally I had a Hypertech programmer. When I got the heads/cam done I needed tuning on a dyno, so the speedo was changed then.
Old Oct 14, 2003 | 12:11 AM
1BAD86Z's Avatar
hi greg, i scraped out the broken gear, oh well.
as for the speedo recal. you will probably have to go to APE.
i do not have the software needed to tap into a ls1 car.
sorry just gears.
Nov 18, 2023 07:21 PM
oldschool
Feb 9, 2016 09:21 PM
TitoPR221
Jan 29, 2015 08:00 PM
4586
Jan 3, 2015 07:22 PM
