Small Shot (35-50 hp) Questions...
Old Jul 16, 2002 | 08:23 AM
Redbird's Avatar
Question Small Shot (35-50 hp) Questions...
Okay... Redbird finally up and running. Getting ready for the NMCA race at Grand Bend, Ontario, Canada July 26,27,28. I will be running the above mentioned small shot.
Herein lie the questions:
1) Small shots like these should require NO ignition timing retard, correct?
2) Small shots like these shouldn't hurt
A4 trans on spray through shifts, correct?
3) A 35HP shot probably won't even be noticeable except on the time slip, correct?
TIA fellow gas heads!
---God Speed, Good Luck and Fast Times to You!---
Kevin Hinkley (HInk) * '94 T/A GT * Best Numbers: 11.952 * 116.83 * 7.566 * 90.51 * 1.579 * Naturally Aspirated 350 ci LT1, No Nitrous, No Blower, No Turbo(s)... Just GOD's good, cold air and gobs of money!
FORMER:
IHRA Bracket World Champion and runner-up
IHRA Bracket World Champion.
NSCA/NMCA EFI Eliminator #6902 Sponsored by:
THUNDER RACING * BMR * DETROIT SPEEDWORKS, INC. * MEINEKE MUFFLER, Jackson, MI. * DISCOUNT TIRE, Jackson MI *
Thank you to all sponsors for your kind help and knowledge!
Old Jul 16, 2002 | 05:13 PM
gb95zconv's Avatar
Post
I wouldnt even mess with a 35 shot on these fat pigs....go 50 or 75 at least and you should be fine on STOCK timing. I would still use a fpss and window switch with any nitrous app.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Jul 16, 2002 | 05:36 PM
KTamez's Avatar
Post
Don't bother with a Retard, The trans should be fine, and yep, you'll probably only see it on the slip.
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
AviatorDave
Dec 19, 2016 06:35 PM
nd4spd200
Aug 21, 2015 09:30 AM
Cam's maro
Aug 11, 2015 07:45 AM
NewsBot
Aug 3, 2015 02:40 PM
Boss002
Jul 24, 2015 10:47 AM
