My purge pic..not the same person as last week.
Old Jul 16, 2002 | 05:05 PM
n2oTransAmLT1's Avatar
Post My purge pic..not the same person as last week.
I figured I would post this picure of my purge kit just for the hell of it. Sorry the pic is kind of crappy, due to the great focusing of a polaroid. http://www.geocities.com/lotus_tt/purgespray.jpg
if the links dont work, just copy and paste them into the address bar.
Also, here is a pic of my nitrous buttons and a few gauges:nitrous, boost, fuel pressure. Plus an AirFuel on the A pillar.
http://www.geocities.com/lotus_tt/gaugesbuttons.jpg
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 16, 2002 | 06:32 PM
Post
I have a boost gauge because I have a supercharger. Its a powerdyne 6psi, polished aluminum supercharger. Its brand new and has been sitting in my garage for about 2 months. It is NOT installed yet because I am saving up another $2200 for heads, cam, springs, valves and rods. Then, over winter Im going to pull the engine and install the supercharger and heads, cam..kit. I put the boost gauge in now because I did not want the empty AC vent.
We have/my dad has a hydrolic lift in our other garage for working on cars. Plus an engine lift. Makes working on these cars a lot easier.
Low 13's on motor.
Low 12's on bottle.
Quickss96
Jan 29, 2016 05:56 PM
cmsmith
Sep 14, 2015 09:09 PM
FryedClutch
Sep 1, 2015 08:24 AM
WPHIG2
Aug 27, 2015 06:37 AM
350350
14
Aug 11, 2015 12:03 PM
