NOS setup, what do you pros think???
Old Jul 11, 2002 | 11:48 PM
Camaro_58's Avatar
Post NOS setup, what do you pros think???
Well, I'd like to think I'm halfway to having this whole kit installed, but I want to do things right, and that means SAFE! so, where should I go from here? I have installed the NOS #5176 "dry" kit. Everything is according to the book. Now, what should I do as far as safety provisions. I have 8mm Taylor wires, an MSD 6AL, and will get colder plugs, but what about a controller, fuel pressure safety switch, also, who has info for that throttle position switch, I hate the damn little microswitch NOS gives ya. Anyone got any answers??? Thanks.
Old Jul 12, 2002 | 08:38 AM
1989gta's Avatar
Post
Yeah that micro switch was a pain in the butt, i just fabed a braket and put it by my gas pedal.
Old Jul 12, 2002 | 09:05 AM
drop top steve's Avatar
Post
A fpss is a must on a wet kit, but not sure how important in a dry kit. The NX elec. throttle switch is nice, moniters tps voltage and is adjustable, it does add a relay and some wiring. I think a controller is the way to go, start the run with a small hit so you have some traction and build up to the full hit, I'm using a Schnitz time based unit.
Old Jul 12, 2002 | 10:57 AM
Post
The weak point of the 5176 is the way it controls fuel pressure. Hence, I would definitely go for a FPSS, set as high as you can get it. And I would recommend a fuel pressure gauge.
What are you doing about spark retard? Do you have any way to monitor the computer... e.g. ScanMaster?
NOS offers the 5176-EO kit..... it comes with an electonic WOT switch, a wiring harness for the switch and a nice little CARB-EO sticker to satisfy your local emissions types. I believe you can buy the "EO" parts as an upgrade for your kit.
For consistancy, a bottle heater and a nitrous pressure gauge. And, depending on how it hits, possibly a purge kit. Obviously these are "performance" items rather than "safety".
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
Old Jul 12, 2002 | 04:34 PM
George Debski's Avatar
Post
I consider an electric bottle opener a VITAL safety item.
One day on the freeway, after wasting a Mustang , my N2O solenoid stuck open, but thanks to my bottle opener, all was well. I would have been in deep doodoo without it!!!
SSMOKEM
1995 Impala SS "Cherry Bomb"
Best ETs: faster than my '65 pickup
Mods: 93% stock
My Super Impala SS Website
Old Jul 14, 2002 | 09:26 PM
Camaro_58's Avatar
Post
Well, that's the kind of feedback I'm looking for. I'm in the midst of accquiring a fuel pressure safety switch. One came with my Jacob's Nitrous Mastermind, but it's a 6 psi switch, not for fuel injection guys. As for the timing retard, the Jacob's unit should take care of that. Also, I do have fuel and nitrous gauges, I'm probably just gonna rig up the NOS WOT microswitch till I get around to getting the NX switch.
Now, someone explain to me exactly why I'd need a purge kit.
Old Jul 15, 2002 | 12:16 PM
gb95zconv's Avatar
Post
If your running dry I dont belive a purge is needed...but the shot will not hit as hard the first time you hit the nitrous after opening the bottle.(in other words your purging into the engine so to speak).
On a wet kit the kit supplies extra fuel immediently so the nitrous needs to be there also to avoid fouling plugs and stumble(still not much of a problem if N2O pressure is @ 900+ psi).
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Quickss96
Jan 29, 2016 05:56 PM
Henson071
Dec 30, 2015 09:55 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
Boss002
Jul 9, 2015 03:33 PM
