MSD6AL and window switch
Old Jul 5, 2002 | 11:57 PM
z2894convertible's Avatar
Post MSD6AL and window switch
Do I need a window switch if I get a MSD6AL for rpm settings for the n2o???
Old Jul 6, 2002 | 04:19 PM
n2oTransAmLT1's Avatar
Post
Yes. You will need the window switch if you want to turn nitrous off after a certain RPM, in case you miss a shift. MSD6al wont do that for you.
`96 TransAm: RamAir w/ K&N filter, 125hp Zex dry kit, 3.73 gears, McLeod StreetTwin clutch, Borla cat-back, 1le alum. driveshaft, B&M shifter, Walbro in-line fuel booster pump, Granatelli MAF, 52mm TB w/Airfoil and coolent bypass, LT4 KM + programmed computer, Accel 8.8 race wires, Zex Hyperformance plugs, MSD Univ. Adj. timing, Window switch, Sport-comp Nitrous, Boost, Fuel pressure gauges in center 3 vents and Air/Fuel gauge on A-pillar pod, Mobil 1 only, !CAGS, Yokohama tires, tinted windows.
Low 13's on motor.
Low 12's on bottle.
"Lots of throttle and a backup bottle"
Old Jul 6, 2002 | 07:07 PM
mtxpert's Avatar
Thumbs up
Forget the MSD, get a Mallory VI part # 685 which includes a programmable digital window switch, timing retard and 2 stage rev limiter. $219.99 at summitracing.com
Just FYI,
Mike
Old Jul 7, 2002 | 08:51 PM
donot_4get's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by mtxpert:
Just FYI,
Mike
</font>
Are they any good compare to MSD?? Every body seen to buy MSD
thanks
leo
1993 Z-28
13.7s@99.97mph
SS hood
Rockford: amps, and sub
Cadence: EQ, and CAP 1.0
BM Quart: components
Pioneer: Head Unit
100% self-install
http://www.tereschubert.com/camaro
[This message has been edited by donot_4get (edited July 07, 2002).]
Old Jul 10, 2002 | 03:05 PM
rpm4lalo's Avatar
Question
<font face="Verdana, Arial" size="2">Forget the MSD, get a Mallory VI part # 685 which includes a programmable digital window switch, timing retard and 2 stage rev limiter. $219.99 at summitracing.com</font>
It say it is out of stock and I can't seem to get a decription of it from Summit.
[This message has been edited by rpm4lalo (edited July 10, 2002).]
Old Jul 10, 2002 | 05:25 PM
Post
I looked for it also and I couldn`t find it.
Old Jul 10, 2002 | 07:16 PM
mtxpert's Avatar
Post
Jegs:
http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
Century Performance
http://www.centuryperformance.com/de...uct_ID=MAL-685
Old Jul 10, 2002 | 07:25 PM
mtxpert's Avatar
Post
Jegs:
Century Performance:
Old Jul 10, 2002 | 07:29 PM
mtxpert's Avatar
Post
Here you go:
http://www.centuryperformance.com/mallory/index.asp
Old Jul 10, 2002 | 07:30 PM
mtxpert's Avatar
Post
I can't post the links on here for some reason
Go to jegs and on the top put in 685 - click on the link for the Mallory VI CD ignition
Also look on the web for 685 and Century Performance
Mike
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
z28cam1993
Sep 9, 2015 04:08 AM
