Do M6 LS1's really burn oil like I've been hearing?
Old Sep 16, 2003 | 07:55 PM
newby's Avatar
So I've been thinking about buying a 98 M6 Z28 and I've been having people tell me the M6's have a bad tendancy of buring oil. Is this true, and if so how common is it? Is it expensive to fix?
Old Sep 16, 2003 | 08:56 PM
zoomjrl's Avatar
they only burn oil when you STAY in High RPMs, 5k-6kRPMS.
Old Sep 16, 2003 | 08:57 PM
Lan01z's Avatar
Re: Do M6 LS1's really burn oil like I've been hearing?
Its true, but not a big deal. Just put a quart in between oil changes.
Old Sep 16, 2003 | 09:43 PM
Omega9's Avatar
My M6 doesn't burn any oil at all.
Old Sep 16, 2003 | 10:07 PM
mr_muff's Avatar
as far as i know it doesn't have anything to do with the tranny. it is just some ls1's burn oil, some don't
Old Sep 16, 2003 | 10:16 PM
Bluntdogg's Avatar
My Low Oil light came on after about 2000 miles from the last change. Mine seems to burn a decent amount of oil, but then again I have been getting on it quite frequently since buying the car.
Old Sep 17, 2003 | 07:55 AM
LeathernecK's Avatar
It is not transmission dependant.
The only oil consumption problem that I am aware of is on the 01 and 02 model year. 01 and 02 also have a valve train noise problem.
Old Sep 17, 2003 | 08:42 AM
camarokid167's Avatar
Ditto
Old Sep 17, 2003 | 09:18 AM
Omega9's Avatar
Thumbs up
I must be lucky, my LS1 doesn't burn any oil at alll, and the valve train isn't noisy either.
Old Sep 17, 2003 | 09:48 AM
02Camaroguy1775's Avatar
Here's some info on engine oil consumption in general... take it for what it's worth, as it came from the mouths of Ford Mo. Co.
My company runs a fleet of vehicles, we have mainly Chevy's, but we got a good deal on a Ford E-350 van. After running it a few months, we noticed a lot of oil consumption, about 2 quarts between changes. We returned it to the dealership for a consumption test. It was still under warranty at the time, they told us at first that it was within their standards for it to burn that much oil, then changed their minds and replaced the engine. They told us that a certain amount of oil consumption is actually built into newer engines, and that by burning a small amount of oil it helps keep the cylinders lubricated and extends engine life. 2 quarts was not reasonable, but they told us about a quart every 3000 miles was well within tolerances. That's what they told us, so again... take it for what it's worth.
Old Sep 17, 2003 | 05:53 PM
Apparently, some 01 and 02 LS1 blocks were built with a couple of cylinders that were slightly larger than the rest........
Old Sep 17, 2003 | 06:03 PM
steelerfan's Avatar
A lot seems to depend on how you drive.If I drive aggressively,wind out the gears & do a lot of down-shifting I use a bit more oil then when I drive more "normally",as my wife calls it !
Old Sep 17, 2003 | 06:39 PM
Schismblade's Avatar
It's safe to say mine doesn't burn any oil. I've been waiting for the low oil light to come one but it hasn't. It's been several months and I think it's time for a change.
Old Sep 17, 2003 | 06:49 PM
codyman16's Avatar
My dads 2001 corvette burns about a quart of oil every 3k miles. there is in fact a fix for it, different piston rings. In fact in 2002 the ls1 engine came standard with the new pistong rings which are supposed to be better at not letting the oil past driving about 3k rpms. the bulliten says it is usually only a prob in the m6 because those are the only people who dirve at low load above 3k because an auto shifts you into a dif gear. I should mention i don have any oil consumpion and i drive at aroun 1800 rpms(even though according to gm this was fixed in the 2002 model). My dad with his vette however drived normally at like 2500 to 3k rpms. But they will fix the prob if you have warrenty and put in the new rings 2002 already has them though.
Old Sep 17, 2003 | 06:54 PM
God forbid you aren't waiting for your low oil light to come on and tell you that you are low on oil...... I imagine, that won't happen until you are down to 3 quarts or less.
