2.8L 84 Camaro misfiring on acceleration
Old Aug 24, 2002 | 11:07 PM
Airhead315's Avatar
Question 2.8L 84 Camaro misfiring on acceleration
I recently bought an 84 Camaro and if you try to accelerate too fast the engine will misfire. It does not misfire in easy throttle but if you rev the engine or accelrate to quickly the engine will immediately misfire.....the problem occurs worse when the engine is cold.I cant find any wacuum diagrams for a 84 camaro V6. The engine was rebuilt and the cylinders bored out.....But the guy didnt connect everything up and he may have skipped over a few things. Do you happen to know where the EGR valve is located? Also, any other suggestions as to what could be causing the problem?
Thanks,
Aaron
P.S. I just recently Changed the plugs and made sure to set the gap to factory specs.
Old Aug 25, 2002 | 02:43 PM
Airhead315's Avatar
Post
Just an Update... Put in new spark plug wires today and plugs yesterday. With no change in the backfireing...but i removed the air filter to the caburater and reproduced the backfire. Flames shot out of the carburater...any idea what could be causing these problems?
Thanks,
aaron
Old Aug 25, 2002 | 03:10 PM
All_InTheRED's Avatar
Post
Valve Timing being off???
Ignition timing being waaaaayyyyy off
Not sure if it has air injection. If it does, check to see that it has manifold vaccum to the air injection manifold.
or even just a bad carb could do it.
Does it "diesel" when you shut it off when hot???
Max
'95 Camaro V6..BB Triflo quad-tip catback, 180 degree Themostat, WaterWetter, K&N Air Filter, AC Delco Rapidfire Spark plugs, TB-Bypass, BMR Chrome-Moly STB, Front & Rear 1LE Sway Bars, 255/50/16 Eagle GS-C & F1 Steel, Dark Tinted Windows. Fog-lights on when Hi-Beam On Mod done tooooo.
www.home.earthlink.net/~airspeedy2
'99.5 F-250 SuperDuty CrewCab,PowerStroke Diesel, 2wd, Torreador Red, TS Extreme Chip & LPG, BTS Tranny & Converter, Maddog Stage 2 Injectors, TTS "Hybrid" Turbo (35psi max. boost), Detroit Locker ......14.2@99mph. 436rwhp/869ft.lbs.
...lets just say its not stock.....well DUH!
AdsoYo
May 2, 2018 03:21 AM
PCLZ28
Dec 24, 2015 05:19 PM
CARiD
Dec 26, 2014 04:20 AM
jayblev95
Dec 1, 2014 06:55 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
