whats in my car!
Old Jul 10, 2002 | 02:11 AM
jons69's Avatar
Post whats in my car!
I have a 1969 camaro, which from the factory had a 307cu motor and a THM-350 tranny, and the only thing I dont know is the rearend. I cant find the codes on the axle shafts to help me out. does anybody know what originally came in the rear-end?
Old Jul 10, 2002 | 07:41 AM
Jeff H's Avatar
Post
The codes will be on the passenger side facing towards the front of the car. A lot of times it is more towards the top. You'll probably need a wire brush to clean all the old dirt off to see it. You most likely have the standard 2.73 non-posi rear with that engine/trans combination. If you're lucky you might have the 3.07 or 3.08.
Jeff H - 69 Z28 Hugger Orange, GM crossram, GM fiberglass cowl induction hood, factory TI setup & factory installed JL8 4 wheel disc brakes - original #'s matching and documented, being restored), 87 Toyota 4Runner SR5 Turbo
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
