Opti Spark Alternatives
Old Sep 1, 2003 | 08:30 PM
Wicked's Avatar
Are there any, who does it and how much??
Saw a guy in a magazine that convereted over to a distributer set up.. also seen some with multiple coil packs like the LS1....
Thanks,
Jason
Old Sep 1, 2003 | 10:07 PM
The only real alternatives are the LTCC or the dynaspark. Both pushing $600 or more in cost.
Old Sep 1, 2003 | 11:02 PM
You might want to do a "search" on advanced tech... there are a couple of very long threads there on alternatives to the Opti. The only "true" no-Opti setups have been the Electromotive SDI/Opti-Eliminator (no longer made, and maybe only 20 in existance) and a prototype setup from New England Dyno that used a crank trigger, a home-brew cam position sensor, and a FAST ECU with the eDIS unit to drive the 8 LS1 coils. There is a long thread about the NED setup on the Advanced Tech board right now, resurrected from last year.
But I think you will find that just getting the high voltage function out of the Opti case (as the LTCC does), and using only the optical sensor portion to feed accurate info to the stock PCM or an aftermarket ECU works very well. The "quickest LT1" (9.04@155 in a 3,900# convertible) used the Opti that way, feeding a MoTeC M48Pro, with their IEX 8-channel ignition driver and 8 LS1 coils... I have the same setup. But the LTCC will cost you only 1/10 to 1/5 as much as one of the aftermarket ECU's.
beltrunner
May 17, 2015 10:18 PM
grabbem88
Mar 18, 2015 01:25 PM
Iamherefornow
Jan 26, 2015 04:57 PM
nophix
Nov 30, 2014 10:26 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
