How can I tell if I have a 8.2 or 8.5 rearend?
Old Jun 24, 2002 | 09:43 PM
Red1's Avatar
Post How can I tell if I have a 8.2 or 8.5 rearend?
Like the sub says "How can I tell if I have a 8.2 or 8.5 rearend?"
I have a 70 Camaro I've been working on and I know 70's came with both. Is there a visual check I can do to find out wothout tearing it apart?
Old Jun 24, 2002 | 10:13 PM
MadMike's Avatar
Post
You can assume:
1970 10 bolt will be an 8.2 They didn't make the 8.5" until 1971.
The alternative is the 1970 12 bolt rear end which was used in high torque cars.
Or you can measure and confirm:
the 8.2" rear end uses u-joints that around ~ 1 1/16". The 8.5 & 12 bolt both have ~1 3/8" diameter u-joints.
In 1971 the 10 bolt was strong enough it negated the need to use 2 different rear ends in the Camaro.
I assumed: My 1973 Z28 has a 12 bolt in it - and a 8.2" yoke. No wonder it broke all to #eLL when the clutch was dropped.
So don't assume anything.
Old Jun 27, 2002 | 09:07 AM
BIGBADBOWTIE's Avatar
Post
In my experience(this may not be in all occasions) The 8.5 10 bolt will have two squared off lugs on the bottom of the pumpkin. The 8.2 will be rounded.
Hope that helps.
[This message has been edited by BIGBADBOWTIE (edited June 27, 2002).]
mrwz28
Jul 8, 2015 09:11 PM
Flint78
Jun 21, 2015 01:28 PM
Speeds8erM-1
Classic Engine Tech
Aug 21, 2002 01:06 PM
shocker45
Classic Engine Tech
Jul 14, 2002 12:56 AM
68 Camaro Conv
Classic Engine Tech
Jul 2, 2002 07:41 AM
