Fly Wheel Recommendations
Old Aug 27, 2003 | 08:35 AM
oneledvr's Avatar
Question Fly Wheel Recommendations
Planning on istalling new high performance clutch. What is everyones opinion on fly wheels? I thinking of goin with a lighter one. I realize goin to light will hurt the engine performance because of lack of momentum/inertia.
Old Aug 27, 2003 | 08:58 AM
IXLR894Z28's Avatar
I have heard lightened flywheels help because it takes less power to turn them, just my .02.
Old Aug 27, 2003 | 09:41 AM
Deadcarny's Avatar
lightweight spin up faster, but they spin down faster also. they are great for road racing where you downshift a lot and need to spin up quick out of a turn.
heavyweight ones spin up slower, but keep the rpm's a lot higher between shifts so you stay in your power range between shifts while drag racing.
it all depends on what you are looking for....my flywheel weighs 37 pounds!
Old Aug 27, 2003 | 10:50 AM
TreySpeed's Avatar
On permanent vacation
With a light flywheel you have very little Kinetic energy. When you launch, you are more likely to bog the motor down. A heavy fly wheel won’t bog down as much off the line.
A heavier flywheel will rob more power- but it is justified in the amount it can "store" off the line.
Now if someone could make a heavy flywheel that safely shed after launching- you'd be in business!
There is no right or wrong answer; it just depends on your application. Obviously within reason, a 250lb flywheel isn't going to help anything!
Old Aug 27, 2003 | 11:18 AM
Brent94Z's Avatar
Super Moderator
I'll move this over to the new Drivetrain forum...
Old Aug 27, 2003 | 11:47 AM
Don 97 SS's Avatar
I have an SLP lightweight FW. It dropped about 8lbs from that of the oem. I have had it in for about 4 years and I really like it. I don't take my car to the track so I can't comment about my experience with 60' times. It is great on the highway!
Victor Lamb
Aug 26, 2017 02:52 PM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Jlo
Feb 3, 2015 09:41 PM
NewsBot
Dec 17, 2014 02:50 PM
