Why do camaros run rich
Old Aug 20, 2003 | 12:33 PM
Red96Lt1's Avatar
Is there any reason they do this?
Old Aug 20, 2003 | 12:40 PM
Very easy.... that's the way they are programmed at the factory.
When you go to WOT, the PCM drops the O2 sensors out of the loop, and bumps the target A/F ratio up to a value significantly richer than the 14.7:1 that is uses in closed loop for low load/low rpm economy. The target A/F ratio in "power enrichment" mode is calculated from a couple of variables, according to tables in the PCM. Typically, you will see a fairly rich 11.7:1 as the target A/F ratio at WOT. That's is a bit richer than the traditional values of 12.8 - 13.2:1 that are assumed to produce peak power and torque.
Apparenty the factory feels they need an overly rich mixture to protect the engine.
Old Aug 20, 2003 | 12:41 PM
Hyperspeed97z28's Avatar
I think maybe for emmisions ?
Red96Lt1's Avatar
How does a rich condition protect the engine, does it keep it cooler?
Old Aug 20, 2003 | 12:50 PM
GaRn's Avatar
yea
usually the leaner, the hotter.. heat kills engines, breaks down oil, etc.. usually engines last longer runnin slightly rich..
Old Aug 20, 2003 | 12:54 PM
It not for emissions. Emissions are only measured/regulated at part throttle, "normal" driving conditions (and remember that's "normal" for mom & pop - not for us ). That's when the PCM operates in closed loop, and maintains an A/F ratio of 14.7:1. That's the point where the combined emissions of HC, CO and NOx are minimized, and provides decent fuel economy.
But 14.7:1 is too lean for power. When it goes WOT, it should be looking for something along the lines of 12.8-13.2:1 for max paower and torque. Some of the people here with good dyno tunes have even found a wider range, maybe somewhere in the low 12's, on up toward the higher 13's.... varies a lot.
But remember, as the engine leans out, it increases the tendancy to detonate. By current production engine standards, 10.4:1 compression is fairly high... and the LT1 is one of the few engines running compression that high. So, I would suspect the factory tries to keep it on the rich side, to prevent detonation. If you get any detonation, the PCM is going to pull a ton of timing, and then put it back in slowly, until it sees knock again. So... you can put in a lot of spark advance, then run it rich to prevent retard and the resultijng power loss, or you can start with moderate advance and run it closer to 12.8:1. Appears the factory chose to push the spark advance up aggressively, and then use a slightly richer mixture to prevent detonation.
All of this is pure guesswork... I haven't the slightest idea what the factory was thinking when they programmed the PCM.
Old Aug 20, 2003 | 04:27 PM
Red96Lt1's Avatar
Thank you for your explaination!
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
Collector Car
Dec 17, 2014 01:12 PM
Donwest22
Parts Wanted
Dec 12, 2014 05:58 PM
Scottylt1
Dec 4, 2014 12:31 PM
