All hell just broke loose on my car!!!!
Old Aug 17, 2003 | 12:58 PM
Fastbird93's Avatar
Dang it. Ok, I've been having the idle problem. Here's what I did today:
Pulled the chip, and hooked it up to EPromer5 so I could read, download, and save the bin file. I do that, and open it in Tunercat. I posted another one about that problem. Anyway.
I put the chip back in the car, and sh*t hits the fan. She idles fine now, but that's about all. Service Engine Soon light is constantly on. When I stomp the gas, I get a stutter and hesitation, then a rev up to 3000, where that's the end. Stuttering and hesitating, no go past 3000. And, the A/C magically started blowing hot air today too. Any ideas? I'm starting to think my chip is corrupt or something, because the car was fine when I got it, and is getting progressively worse as time passes.
Old Aug 17, 2003 | 02:52 PM
Fastbird93's Avatar
Ok, after playing more, the 3000 rev limit is like it's hitting the rev limiter. It just bounces off and comes back to 3000. The A/C clutch is not engaging at all.
BUT, the most thought provoking thing is that when I tried to run datamaster, it could not connect to the PCM. I would press the start button to begin logging, and would get the message "No PCM sync....recycling...". Did the PCM fry or what?
Old Aug 17, 2003 | 03:05 PM
allmotorta's Avatar
When I installed my chip wrong (it was a piggyback chip, I didn't install it piggybacked) it did exactly what you described. 3000 rpm rev limit, hesitation, etc...I installed it correctly, and all was good. Hopefully your ecm isn't fried, the chip might not be fully engaged in the pins or something dumb
Old Aug 17, 2003 | 03:09 PM
Fastbird93's Avatar
The chip is an Amtel 29C256 reflashable chip on a Moates piggyback adapter. Is there a top and bottom end to the Amtel chip?? I'm going to feel like a moron if it's upside down.
Old Aug 17, 2003 | 03:49 PM
Fastbird93's Avatar
Well, I switched the Flash chip around, nothing, wouldn't even start. Swapped it back, and swapped the original chip around. Nothing again, no start. Swapped them back to normal, started, same problems persist. I then proceeded to swap piggyback adapters since I have another one, and the problem still persists.
Any ideas? Anyone? I need help!
Old Aug 17, 2003 | 03:59 PM
Fastbird93's Avatar
FIXED!!!!!
Well, sorta. I pulled the piggyback harness, and put the semi-stock chip that was there in. WHAM! Fired up, idled nice, idled with the A/C on, which is blowing cold air again, and revved all the way up!!!!
So, on to the more pressing issue: Which could be bad? The chip, and does that happen? Or BOTH of my piggyback adapters?
Old Aug 17, 2003 | 04:02 PM
madwolf's Avatar
The chip is most likely fried.
Old Aug 17, 2003 | 04:06 PM
Fastbird93's Avatar
You Sir, are the man. Thanks for the help!!
ANDYZ28
Dec 29, 2014 09:13 PM
heavenly_six
Dec 10, 2014 12:23 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
