Engine back fires and misses.
Old Aug 14, 2003 | 05:24 PM
killer-of-pony's Avatar
93camaro, the engine has a loss of power when i junp on it (wot) it will also miss and backfire at almost redline. when i drive it around it seems fine but when i get on it there just doesnt seem like there is any power. i checked the fuel pressure and it was fine. i also replaced the coil and that didnt help. the computer is not flashing any codes. has anybodey else had this problem, and how did you fix it.
Old Aug 14, 2003 | 05:28 PM
12SCNDZ's Avatar
Have you ever changed your catyletic converter? Sounds like what mine was acting like when it was clogged. After you turn the car off, pull the hood, and see if your exhaust manifolods/headers are glowing red.
Frank
Old Aug 14, 2003 | 05:30 PM
i did put a high flow cat on. but my cat does constintly scrape on speed bumps and other stuff
Old Aug 14, 2003 | 07:18 PM
please HELP!!! ttt
Old Aug 14, 2003 | 08:42 PM
How about basics like plugs and plug wires? No one like to say optispark, but that is a possibility, too.
Old Aug 15, 2003 | 12:25 PM
sorry guys but i need some help. ttt
Old Aug 15, 2003 | 12:35 PM
KeVMaN's Avatar
something in your ignition. crappy or uncorrectly gapped plugs, wires, coil wire.
Old Aug 15, 2003 | 01:20 PM
So you checked plugs and wires? How did they look?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
