A4 radiator with m6 swap
Old Aug 14, 2003 | 01:20 PM
VINCELEE123's Avatar
sence tranny fluid passes through the radiator with an auto,
would i need a m6 tranny if i was gonna do the swap?
Old Aug 14, 2003 | 01:23 PM
KCFormula's Avatar
If you are swapping from an auto to a manual, no. You can just leave the fittings loose.
Old Aug 14, 2003 | 01:46 PM
Geezer powered's Avatar
I know you can leave the auto rad. in there,but does the manual rad. have more cooling do to it not having the passing of trans fluid?
Old Aug 14, 2003 | 01:52 PM
ok, so i would not need it for the swap.
Old Aug 14, 2003 | 01:57 PM
The cooling tubes take up a very small amount of space inside the RH tank of the radiator. Not enough to worry about.
Old Aug 14, 2003 | 02:37 PM
Dave Feerst's Avatar
yep, but if I were you I'd get a couple pipe pligs and close off the ports, to keep water/corrision from getting in. Wont even cost ya a dollar, and you'll be glag you did if you ever put an auto in there or sell the radiator.
Fatdog2
Apr 27, 2015 10:32 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
