93 hotcam/ported heads/pcmforless users, please read.
Old Aug 6, 2003 | 08:22 PM
max929's Avatar
I have ported heads with larger intake 2.00/exhaust 1.60, pcmforless chip, SLP midlength headers, Flowmaster muffler, and Hotcam. 93 Z28 M6
I only mustered 300hp 316tq on the dyno. I know this has to be low.
I still have stock injectors and the last time I read my fuel pressue it was at 36psi. I think this is low reading. Curious on what my problem is.
Compression test within paramerters, lowest reading 155 and the highest 160psi.
The only driveability problem I have is a buck under light throttle and lopey idle, goes between 750rpm to 850rpm. I was told by another Comp Cam user this is normal for my cam.
Any suggestions?
Old Aug 6, 2003 | 08:29 PM
faded93bird's Avatar
well for one was your fuel pressure reading taken with the vaccume disconnected ? if disconnected that is low and a new filter and maybe a pump should be considered
you also need bigger injectors at least a step higher with 24's but 28's or 30's would be better just get programing for them
and what your feeling is a little cam surge
FastZinTennessee's Avatar
Well I have a 95, PCMforless did my tune. I picked up almost .4 in the 1/8, and 3+MPH. However, I don't think the guy that programs the 94 and up PCMs does the chip work.
What kind of shape are your plugs/wires etc. in?
IMO with some good head work your combo should be good for mid 300 rwhp. Good luck in getting it sorted out.
John
2QUIK6
Sep 17, 2016 02:31 PM
maverickmk
Sep 1, 2015 09:17 PM
FryedClutch
Sep 1, 2015 08:24 AM
cmsmith
Aug 25, 2015 09:42 AM
mrwz28
Jul 8, 2015 09:11 PM
