QUESTION ABOUT LIFTTERS
Old Sep 10, 2002 | 05:02 PM
ROGERARRAMBIDE's Avatar
Question QUESTION ABOUT LIFTTERS
Hi
I dont know if its common, but 2 of the Camaros I had, had lifters problems, they sound like no oil, or takes too long time to charge of oil.
Right now, my 99Ls1, when starts in the morning, dont make any bad sound, but if I left on, in 1 or 2 minutes, starts to hear that sound.
Other way, when starts to run I can hear to much noise or at least most than the normal noise like earlier engines that need to calibrate the upper parts because they werenīt hidraulic.
Any one knows if may be need some calibartion or i need to replace the liftters?
Red Camaro Z28 1999 LS1
Old Sep 10, 2002 | 05:05 PM
Btchslp's Avatar
Arrow
You shouldn't have to replace lifter on a car so new. Try checking your oil level and make sure you have it filled correctly.
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, SLP loudmouth
ported MAFs, Nitto 315 DRs
Currently: 1/4 13.06@113.8 (gtech runs high in mph by about 4mph), 0-60 4.77 (w/passenger) Gtech'd
12.99@110.2, 2.06 60ft - Tazzo.
Also, 331 rwhp as measured on the Gtech
Old Sep 10, 2002 | 05:23 PM
Post
Of course that I already change the oil and filter, but donīt stops that noise.
I use the Quaker State 20W40 "FOR HIGH PERFORMANCE ENGINES"
Old Sep 11, 2002 | 03:00 AM
X DSM'er's Avatar
Post
Only tapping I had was when using Mobil 1 5w30. I changed to 10w30 and no more tap.
'92 Talon TSi AWD
13.8 @ 97mph 1.74 60ft
Not stock
'99 Z28 M6
Mods/Info: Click here!
Best Time: 13.3691 @ 106mph (no N2O)
60ft: 2.12
AOL IM: Bubblesnaps
Old Sep 11, 2002 | 11:42 AM
ZZed's Avatar
Post
I'd go with Mobil fully synthetic oil. 5w30 prefered. 10w30 also OK. 5w50 also good. I would personally never use 20w40 oil. That's just me. I live in a colder climate, though. I'll stay with 5w30 until the engine has high mileage, always staying with synthetic. What is your oil pressure reading?
2000 Camaro Z28 Monterey Maroon Metallic, A4 ,leather, 323 posi, Monsoon w/CD, T-tops, K&N
Old Sep 11, 2002 | 12:14 PM
Post
In my past LT1 96, used once the 5W50 and I feel that made more noise so, again use 20W40.
Right know the oil pressure in warm and at 650rpm is 275Kpa thatīs right the middle of the mark in the dash.
The other cars I had, dont had too much preasure because the LT1 i remember that, when was warm, mark too down, not in red, but too down and the 98īLS1, wasnt too down but downer that mi actual car.
TTOPS, Leather Beige inside, 25,000 miles
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
