What happens if you warped your heads??
Old Jul 26, 2003 | 04:59 PM
speed76demon's Avatar
just wondering i have heard a lot about it lately if your engine gets to hot it can warp your heads so i'm wondering what are the symptoms of warped heads?
Old Jul 26, 2003 | 05:01 PM
whitetrashT/A's Avatar
Same symptoms of a blown head gasket I believe.
Old Jul 26, 2003 | 05:50 PM
thewinner's Avatar
Yup. Same as a blown head gasket most likely. Loss of coolant, loss of compression, ****ed up bottom end ()
if you suspect you have warped heads, i would run a compression test on it asap before damage gets worse.
Old Jul 27, 2003 | 03:28 AM
Ai's Avatar
Ai
If you get a head hot enough to warp it significantly and lose gaskets, then you also run the risk of softening it. Generally it'll get softest between the two adjacent exhaust ports. When this happens, you'll usually blow out that narrow section of the gasket. In a situation like that where you've got crossfire between cylinders, it can erode (as in blow out chunks) the cylinder head or block & trash either/or.
Generally on street stuff we like to see a minimum HRb 45 between those ports. If you're worried, find someone around you with a hardness tester and have it tested, it should cost next to nothing and is definitely worth it. Oftentimes theyll only be soft at that center section, and sufficiently hard out on the deck of the head. In that case, there's two options... re-heat treat the entire cylinder head, or remove that material and build it back up with an aluminum alloy of sufficient hardness. IMO, the first option is probably a waste of time on cheap street stuff, because after it's treated you'll need to go back and have every machined surface/guidehole re-machined so they're true & properly located. The latter option isn't as big a deal. The centersection is ground away, and simply built back up via welding. To be hard enough without being heat treated however, you end up having to use a pretty expensive welding rod, but I honestly can't recall the name of it.
Overheating aluminum heads is a bad idea... if you think you're doing it, STOP & figure out what's up before you toast your stuff .
-Phil
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
