Weird fluctuations on oil press gauge. Mobile one oil filter the reason?
Old Jul 25, 2003 | 04:39 PM
JTS95TA's Avatar
I friend mentioned to me that Mobile One oil filters are the best for filtration, but horrible for flow. Well a couple weeks ago I brought up a point to him asking why under WOT my oil pressure gauge fluctuates down, then goes back up. This was starting to concern me and I didnt realize that the Mobile One oil filter was so poor in the flow numbers. Has anyone else noticed this using this filter? or would this not be relrated to the oil filter? I am due for a change very soon so I will go back to the Delco filter and see if it corrects the problem. Anyone else have any input on this??
Old Jul 25, 2003 | 04:51 PM
Geezer powered's Avatar
go over to the advanced section.there is something there that will have the answer for you.It should be one of the first couple of posts.
Old Jul 25, 2003 | 05:13 PM
94formulabz's Avatar
Here's the adv tech linkhttp://web.camaross.com/forums/showt...hreadid=144932
Mobil 1 filter horrible for flow? Thats BS. Maybe it wasn't the best in this test people are refering too, but does that make it horrible? I'd rather have some good filtration than just the absolute highest possibly more than neccessary flow capacity.
Old Jul 27, 2003 | 03:45 AM
QCKZ28's Avatar
i use a kn filter, it filters almost as good as the mobil 1, but fit flow much better. also ditch the oil cooler and use the bigger filter last 4 digits are 3002 instead of the oem 2002.
HectorM52
Jul 30, 2017 11:46 AM
captcorvette
Mar 7, 2015 12:37 PM
97z28k&N
Jan 9, 2015 04:58 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
!!!TED!!!
Aug 27, 2002 05:41 PM
