is the clutch going?
Old Aug 18, 2002 | 02:42 PM
court99z28's Avatar
Post is the clutch going?
I need to know how to determine if my clutch is starting to slip. what are the ways or signs to test and know that it is the clutch.
Old Aug 20, 2002 | 07:32 AM
Desolate_Flux's Avatar
Post
Wouldnt know man, I've only been driving a manual for 1800 miles of my life =) I'll find out sometime, I'm sure... But I'm curious myself.
-2002 Red Camaro SS
Chesapeake, Virginia
http://www.HeadRushPerformance.Com
Old Aug 20, 2002 | 08:40 AM
bbentley40's Avatar
Post
When the clutch started going out on my 95 Camaro you could tell because if you really got on it the engine was a lot louder and not going as fast as it used to, and if you are in like 4th or 5th (it was a v6 only 5-speed) and pressed the gas the rpm's would go up anywhere from 500-1000 before the car would begin to speed up.. at which time the rpm's would go back to where they had been and continue to climb while accelerating.
Dont know if that helps much, that is just the 2 things I remember happening the most when my clutch was going out.
Bentley
2000 Camaro SS
M6
Direct-Flo Air Lid w/ K&N
Ported MAF
Free Ram-air
Trimmed EGR
Old Aug 20, 2002 | 10:47 AM
Chad01Z28's Avatar
Post
Accelerate normally up to around 35mph. Put it in 6th gear and floor the pedal. If it bogs or accelerates very slowly then the clutch is fine. If the rpms shoot up any, the clutch is slipping.
2001 NBM Z28 6-speed
Whisper lid, SLP CAI, Corsa exhaust, Pro 5.0 shifter, McLeod Organic/Kevlar clutch, BMR STB
Best ET:12.797@110.52(1.985 60'), Best MPH 12.835@111.04
Moderator at The F-body Hideout
[This message has been edited by Chad T 98 Camaro (edited August 20, 2002).]
Old Aug 20, 2002 | 03:08 PM
Eric @ DMS's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Chad T 98 Camaro:
</font>
Ahh beat me to it...that's exactly what I was going to say. Good luck
Eric Cuaresma - CamaroZ28.com Sponsor!
President/Co-owner of Dynamic Motorsports, LLC (DMS)
"Leaving the competition behind..."
Website: http://www.dynamicmotorsports.com
Email: eric@dynamicmotorsports.com
- A performance company by performance enthusiasts FOR performance enthusiasts!
WE WORK TOWARDS HELPING YOU, NOT TOWARDS MAKING MONEY!
Old Aug 24, 2002 | 09:43 PM
SpikeLS1's Avatar
Post
On both my LT1 and my LS1 the clutch's engagement point slowly moved up the lever's travel until it was at the very top (ie, your foot was as far off the floor as it could get before the engagement point was hit)... this was the first sign of my clutch dying.
The second sign is that when you floor it at low rpms (ie 1500-2500) the engine revs up too fast for the miles per hour you are actually going, sorta like you are spinning your tires a bit but you aren't... as your rpms go up higher the slipping will stop and the clutch will do it's job. While the clutch is slipping you are not accelerating as fast as you should be, once you rev higher the clutch will "catch" and you will accelerate correctly. You WILL notice this when it begins to happen, it is impossible to miss. Once it starts to happen you had best stop the tire smoking launches and low rpm punches because it will become unusable QUICK if you continue to abuse it.
My LS1 clutch began slipping at 14,000 miles. My LS1 now has 15,000 miles and I will be replacing the clutch in the next month or two. I did not stop abusing it and it is toast after less than a month and 1000 miles upon noticing the problem.
My LT1 clutch began slipping at about 35,000 miles (about 5 years ago!)... it now has 83,000 miles on it and still hasn't been swapped. However, when it started slipping I stopped abusing it and the car became my daily driver, and the tired clutch has lasted a very very long time because of the lack of additional abuse.
I drove both pretty much the same before the clutches started slipping, however I modded the LS1 alot and it makes *alot* more power than my LT1 so it died alot faster because of that I guess.
'02 Z28 : MTI lid, TTS headers, Corsa exaust, ASP pulley, Pro5.0 w/Lou's ShortStick, Konis (front) Bilsteins (rear), 35mm ST swaybar, SS wheels, SLP SFCs, disabled DRLs, *all* the free mods! :NEXT: ported TB?, NAAAAWZ?? LS1edit???
Old Apr 30, 2003 | 01:06 AM
fbird95's Avatar
I get the slipping, but only in 4th and up, not in the lowerr gears, is this the same problem.
Old May 4, 2003 | 02:30 AM
fbird95's Avatar
the slipping in 4th moved into 3 rd in a matter of days, and i dont drive the car agressively. When it started slipping real bad up a hill on the way home the other night, i knew its time was up, the next day i had a new one put in.
Old May 4, 2003 | 07:46 AM
Drumhawk's Avatar
I'm curious? I'm a little hard on the clutch when I do a burn-out. Before I wear mine out I'd like to know how much dough it will cost to replace it?
Old May 4, 2003 | 09:11 PM
Think U Can's Avatar
Depends on how much you want to spend.My clutch is about a grand!
Old May 4, 2003 | 09:15 PM
Firstgenboy's Avatar
What if the clutch chatters? Is that bad? When you let it out it begins to vibrate a bit? I think mine might be going out too or may need some type of adjustment because it chatters when i let it ou most off the time and the car grinds the gears a little every now and then, mostly in colder weather. like 50* or lower.... any help would be greatly appreciated.. thanks
Old May 4, 2003 | 10:57 PM
fbird95's Avatar
Well the chatter is normal, especially if you got the clutch changed. As fpr the grinding, that sounds more like a syncro issue.
My clutch ran 600.00 for a as good as stock set up.
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Ericksd
Sep 16, 2015 07:08 PM
