Replaced the Rad Cap.
Old Jul 22, 2003 | 07:11 PM
TobyZ28's Avatar
I don't think The previous owner ever replaced the cap on the Rad before. I've been trying to diagnose why my low coolant light comes on and I was thinking it has something to do with the cap.
Well, just picked up a new cap today.. the old one was definatly worn out, I could push the spring down fairly easily. On the new cap.. it's quite a lot harder to push the new one down then the old one: I must have only been holding 8-10 PSI instead of the 18 or so they're rated for. Also, the design has changed slightly... the writing on the outside has changed a bit and the components inside look a bit better built. The spring on the new Rad cap also looks abit "shorter" overall as well. Anyhow, if you haven't replaced your cap in the last 2 years, its probably not a bad idea... 15$ cdn.. so 10$ USD
Old Jul 22, 2003 | 08:12 PM
RCF925's Avatar
Most likely the low coolant light is due to the sensor being bad . Mine does the same thing, I just unplugged it.
Old Aug 26, 2003 | 01:43 PM
kimquigley's Avatar
I got a new radiator cap at AutoZone for $2.99, but the low coolant light is still on. However, I still think that the radiator cap was bad because it blew off last time the car overheated. Not good.
Old Aug 26, 2003 | 02:00 PM
1994CamaroZ28's Avatar
Your car by all means should not be overheating, and the light is cuased by the low coolant temp sensor down below the cap on the side of the radiator you can see it easy.
Old Aug 26, 2003 | 02:08 PM
kimquigley's Avatar
The coolant was hot, but definitely not low.
Old Aug 26, 2003 | 02:14 PM
*bonk* lol just because it might not be low doesnt mean the sensor isnt dirty/bad unplug it and see if the light goes off, if it does you need to clean/replace the sensor.
Old Aug 26, 2003 | 02:16 PM
kimquigley's Avatar
That's the plan
calaban
May 18, 2020 06:43 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Sandersen511
Jan 13, 2015 03:49 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
94B&RZ-28
Dec 22, 2008 10:00 AM
