Antitheft Radio Code
Old Aug 18, 2002 | 04:45 PM
BLACK00Z28's Avatar
Question Antitheft Radio Code
I bought my Z28 used and have no idea about the code for the radio. I don't need it yet since I haven't disconnected the battery, but I'd like to know it or how to reset it. I doubt the previous owner changed it. Would it still be set from the factory? How do I deal with this? If I disconnect my battery and don't know the code I won't be able to get the radio to function, right?
Black 2000 Z28
T-tops
6sp w/ Hurst Shifter
Old Aug 18, 2002 | 06:07 PM
MonteSS427's Avatar
Post
The battery disconnect/radio code, I believe, is in your owners manual.
| There is no replacement for displacement |
| Soon Future F-Body Owner !
Old Aug 18, 2002 | 11:26 PM
BlueLS1Z28's Avatar
Post
is the led on your radio flashing?if not then the lock function has not been set and you won't need a code.the factory setting is 000 by the way.
Old Aug 19, 2002 | 09:24 AM
TireSmoke's Avatar
Post
Maybe it's different with the Trans Am stereo, but I had a separate code from the factory that came on a sticker that was attached to the front of the head unit. I pulled the sticker off and keep it in a safe place. I don't remember the number off the top of my head, but I know it wasn't 000. In fact, I tend to think that it was 4 digits, but I could be wrong.
Steve
2002 Trans Am WS-6
M6, Pewter, Flowmaster 80 Series, and CAGS eliminator (FINALLY!)
Old Aug 19, 2002 | 09:29 AM
ZZed's Avatar
Post
You will need the code if you ever want to use the feature, which I recommend. Take it to the dealer you bought it from (if it's a Chevy dealer) and they can reset it. Any Cheavy dealer could reset if to factory 000. You manual should tell you what you need.
2000 Camaro Z28 Monterey Maroon Metallic, auto,leather, 323 posi, Monsoon w/CD, T-tops, K&N
Old Aug 19, 2002 | 10:55 AM
goaliedave40's Avatar
Post
If you haven't diconnected the radio, your owners manual will tell you how to change it. If the dealer has to reset it, they might jab you for 40.00. Yikes. Hope this helps.
1999 Z-28 M6: Gran.MAF, LS1 MoSports intake, K+N filter,Corsa exhaust, PowerSlot rotors, Hoch. strut tower bar, still working
Old Aug 19, 2002 | 07:52 PM
rk3red's Avatar
Post
Go to LS1.com. There is a faq thread in one of their electronics boards and will show you how to get it. Try this link http://www.ls1.com/java/rotate2.htm
It worked on mine and I'm forever greatful for it.
1997 Camaro SS
Build # 1947
black exterior
granite leather interior
SLP Loudmouth exhaust
K&N modified air filter
K&N valve cover breather
Audio system
http://www.netsnapshot.com/users/8475/images/hth_PLo7uMCoBQIAABFcT9A_8475_0.jpeg
http://community.webshots.com/storage/1/v5/5/83/36/35658336ZQDjXf_th.jpg
eanhl2004
Apr 4, 2015 12:01 PM
warmeck
Mar 22, 2015 10:28 AM
Jul 4, 2005 05:00 PM
91Bird305
Aug 5, 2002 01:39 PM
