Have LT4 conversion, but what NEXT???
Old Jul 21, 2003 | 08:55 AM
formula383's Avatar
I have the LT4 conversion with all the mods listed in my sig. I went to the track on Friday, it was very hot ond humid. But anyway here is what the car ran
1st run
1.76 60ft.
5.18 330 ft
8.077 1/8 mile at 84.349
12.717 1/4 mile at 105.730
Adjusted fuel pressure after that run
1.82 60ft
5.22 330 ft.
8.11 1/8 mile at 84.385
12.745 1/4 mile at 106.051
On the first run, the car got towards the end of the track and actually stopped pulling. I mean the rpm stayed the same and everything.
Anyway , what I want to know is how can I make it faster. Do I have something wrong?
Do I need some little something? What mods will help me the most from here??
Old Jul 21, 2003 | 09:03 AM
joeSS97's Avatar
If you used the LT4 springs,I would upgrade.They might be the reason your car stop pulling.Your times are nice tho.
Old Jul 21, 2003 | 09:05 AM
formula383's Avatar
It only did it on the first run though It felt like it was pulling fine on the other runs.
I will keep that in mind though.
Bobby
Old Jul 21, 2003 | 09:26 AM
I'm no expert in the LT4 conversion, but the MPH looks low. And, based on the comparison of the 1/8th MPH to the 1/4 MPH, the problem exists all the way down the track. My calculator says 106MPH in a 3,650# car (my assumption) is about 340-345flywheelHP. I hear about people pulling 400flywheel and better with that setup, and that would show up as 111MPH.
Old Jul 21, 2003 | 09:27 AM
bradpreece95z28's Avatar
Not meaning to hijack your thread...
But, did you buy your car off shawn at Mccoy Motorsports???
If so ...I know that car lol.
I live in Mingo county, West Virginia.
Did you run at Clay City?
That is a moderately slow track anyways.
Shoot me a pm man.
Old Jul 21, 2003 | 09:31 AM
TheHeadFL's Avatar
Based on his fuel pressure comment, and the fact that he got faster by (presumably) raising the fuel pressure, its possible that he is actually running so lean at the end of the run that its almost like he is hitting a 'rev limiter/fuel cut' if its even possible.
Old Jul 21, 2003 | 09:47 AM
Not sure which way he adjusted it.
What is the elevation of the track? Do you have the temp, barometric pressure and humidity, so we can convert to "standard" conditions?
Old Jul 21, 2003 | 10:03 AM
94formulabz's Avatar
is this bone stock lt4 heads? Is it a 383 bottom end?
Old Jul 21, 2003 | 11:23 AM
Antz97ZNJ's Avatar
your mph's are low, bolt on LT1's cut those traps...but i can see how the heat n humidity would kill that
Old Jul 21, 2003 | 10:49 PM
formula383's Avatar
The fuel pressure was way low, and I adjusted it up.
The car has stock LT4 heads and a stock LT1 bottom end.
I thought the mph was low too. That is why I need a little help. A little later in the evening I ran a 107 pass though.
I don't know what the elevation is, or any of the other things.
More help please.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
