slugish when warm
Old Jul 20, 2003 | 02:48 PM
camaro9402's Avatar
slugish when warm
what would cause my car to run slugish when it gets warm?
Old Jul 20, 2003 | 02:54 PM
94formulabz's Avatar
They all do.
How sluggish are we talking about?
Old Jul 20, 2003 | 02:55 PM
camaro9402's Avatar
not real bad just wonderin why they do this?
Old Jul 20, 2003 | 03:18 PM
a number of reasons. First off any motor will make less power when the ambiant temperature is hotter because hot air takes up more volume so you get less O2 molecules in the cylinder to react. Hot motors are usually when it's hot out. That is the idea behind a 'cold air intake'. If you haven't done the TB bypass then this furthur heats up the intake air as the coolatnt gets hotter making the power loss even more. Also, electrical systems don't operate as efficiently when they are hot. My old CJ7 motocraft ignition would get heat soaked so badly with the motor only around 190 that it wouldn't even run. Let it cool off and it fired right up.
I can't think of any other reasons, but thats the main causes.
Old Jul 20, 2003 | 03:44 PM
Antz97ZNJ's Avatar
Thats just the LT1...you'll realize that the intake gets real hot..it happens w/ the LS1 also but not as bad...all cars run sluggish is hot weather
David Dempsey
Mar 12, 2016 12:42 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
greenzee28
Sep 25, 2015 04:29 PM
tdigger9899
Sep 7, 2015 10:56 AM
