speedo off?
Old Jul 18, 2003 | 11:03 PM
blackz151's Avatar
speedo off?
with my new rims/tires 275/30/18's how far off ill it set the speedo
Old Jul 18, 2003 | 11:14 PM
275/30-18 is too small.... the outside diameter is only 24.50". More than 1" smaller than the stock 25.66". That means the tires will be spinning 4.5% faster than the stock diameter, and the speedo will read higher than actual speed by that amount. At a true 60MPH, your speedo will read almost 63MPH. When you drive 1,000miles, your odometer will rack up 1,045 miles. 275/35- or 285/35-18 is the size that matches the stock diameter. Worth correcting in the PCM.
Doesn't that make the gap between the tire and the fender opening even larger?
Old Jul 18, 2003 | 11:22 PM
blackz151's Avatar
yea its 275/35/18 sry
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
LazyLemming
Aug 29, 2015 07:36 PM
4586
Aug 24, 2015 11:04 PM
