Boost on hyp. pistons
Old Jul 18, 2003 | 10:57 AM
12Second3rdgen's Avatar
Hey all. I have an 82 Camaro with the following:
350HO Crate engine (hyp pistons, nodular iron crank, LT1 rods)
Comp Extreme Energy 274 cam (230/236@.050, .478/.480 w/ 1.5)
Ported and Polished Vortec heads, shaved with shim gaskets for 10.06:1 compression
Super victor for vortecs intake, Speed Demon 650 mech secondary carb, MSD pro billet distributor, MSD blaster 2 coil, MSD 6A ignition
TH350, Hughes Pro Street 3000 stall, 3.73's and SLP POSI
My best pass with a crappy 2.0 60 foot is a 12.68 @ 108.91. I am looking for some more power after I get sticky tires. I have been looking at ATI Prochargers for some time now. Do you guys think my bottom end will handle a P1SC running 6-7 intercooled PSI? What kind of gains do you think I will see in both mph and 1/4 mile.
Old Jul 18, 2003 | 12:50 PM
rskrause's Avatar
Moderator
A small nitrous shot will do as much for your quarter mile times as a low boost blower and be much less likely to give you a "free admission" to the "bought a SC, did a rebuild" club.
Rich Krause
Old Jul 18, 2003 | 01:02 PM
Thanks for the advice! So you think a 100 shot would be sufficient on hyp's?
Old Jul 18, 2003 | 04:19 PM
CRZYTRN-92Z28's Avatar
Hypers don't like boost at all. If your gonna put a procharger on there i'd defintetly invest in some forged pistons.
Old Jul 18, 2003 | 05:25 PM
Sparkz28's Avatar
Hit it with a wet 100 shot.....
you should be in the high to mid 11's with a 100shot and maybe trap 118....thats just a guess
Old Jul 21, 2003 | 08:11 PM
1994B4C's Avatar
I dont think the Hyp. pistons like nitrous or boost. Sure you can use either one and make the pistons live, just use really good gas and becareful with the timing. With either one start off small and read the plugs, if you don't know how to read plugs let me know and I will get you a really good article that also explains what small steps to make to keep stepping up the power.
Old Jul 22, 2003 | 01:09 AM
texlurch's Avatar
Hypercrapticinstamelt pistons are actually fairly strong and light
BUT they do not tolerate detonation or preignition at all, especially with added heat from boost. The ring land will usually melt and disappear out the exhaust.
I have sprayed a 200 shot on them, and am now running 12 psi of intercooled boost. As long as you don't detonate them, they will hold up ok.
BUT if you plan on abusing it regularly at the track with spray or boost, forged are cheap insurance against replacing the entire motor.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
