Doing an oil change, first time on my baby
Old Jul 17, 2003 | 10:46 PM
RyanMacZ28's Avatar
Easy question, what kind of oil brand weight do you guys think I should use?
Old Jul 17, 2003 | 10:50 PM
AsianSensation's Avatar
Any API certified 5W-30 will do.
Old Jul 17, 2003 | 10:55 PM
jasons93z's Avatar
i use mobil 1 10-30
Old Jul 17, 2003 | 11:40 PM
96LT14u2Nv's Avatar
it is up to u. any brand of 5w30 or 10w-30 will do just fine.
i use a AC delco filter (part # PF25)
Old Jul 18, 2003 | 12:01 AM
CamaroBoy96Z28's Avatar
Valvoline durablend 5w-30. PF25 AC Delco filters are no longer made. I found this out when I tried to buy one. Its actually PF454, the one I settled on.
Old Jul 18, 2003 | 12:52 AM
fast_TA_95's Avatar
Talking EASY JOB
I work at a quick lube and change about 50 cars a day.My 1995 TA is about the easiest car ever to do. I use rottela T for turboe diesel trucks but i have many many mods including nitrous this oil is so thick you would think it would slow do the pistons but it is a very high quality oil that hardly breaks down after 3000 miles. if you have very littl moods i would use mobil 1 10w 30 synthetic a little more than what u need but more protection can NEVER EVER HURT!!!!
Old Jul 18, 2003 | 03:33 AM
Patman's Avatar
Visit this site:
http://theoildrop.server101.com/cgi/ultimatebb.cgi
Old Jul 18, 2003 | 07:09 AM
texasTA's Avatar
Mobil 1 synthetic 10W-30 and a Mobil 1 filter
Old Jul 18, 2003 | 08:59 AM
Bastardcat's Avatar
Old Jul 18, 2003 | 05:25 PM
RyanMacZ28's Avatar
hey guys, two more questions. First one, exactly how much oil do I put into it? The car is up on jack stands as we speak. Also, does anyone here have the links to the owners manual and the parts catalog? I lost them when I restarted my comp and had to reboot everything, thx.
Old Jul 18, 2003 | 05:43 PM
RyanMacZ28's Avatar
Someone here has to have some idea about how much oil it uses. No manual came with my car, and I downloaded the one from the forum a month ago, but I had to reformat the comp. Anyone??
Old Jul 18, 2003 | 05:47 PM
MentalCaseOne's Avatar
Doing it for the first time I would suggest some KY Ultra gel.... errrrr Wrong thread sowwy
I said you cant go wrong with Synthetic oil....
My 2 cents..
Old Jul 18, 2003 | 06:05 PM
97silverz28's Avatar
Your LT-1 uses 5 qts of oil.
I use the PureOne oil filters by Puroilater.
If you only have the front end jacked up, so the car looks like its doing a wheel stand, you're leaving a bunch of oil in the pan. You wouldnt need to add 5 qts in that case.
Old Jul 18, 2003 | 07:01 PM
Black_Z28's Avatar
I thought it is 4.5qt. in the LT1. Maybe I'm wrong.
By the way I use Mobil 1 Full syn. 5w-30. with a Fram filter.
Old Jul 18, 2003 | 07:08 PM
Patman's Avatar
The manual lists 4.5 quarts but it's wrong, it's 5 quarts. You can go with 5.25 if you run the long filter.
