will the lt4 knock mod work on 93?
Old Jul 14, 2003 | 09:36 PM
93LT's Avatar
everywhere i see the module advertised, it says 94-97. will it not work on the 93? and why not?
Old Jul 14, 2003 | 09:40 PM
Got-LT1's Avatar
To the best of my knowledge, the 93 dosen't really use a knock sensor like the 94-up. The 1993 is not a sensitive to false knock anyway. However, if you still want to desensitize it, there is a webpage that tells you where and what type of resisters to put in a wire, I am sure someone can post it.
Old Jul 14, 2003 | 09:53 PM
93LT's Avatar
would really like to know that site.
Old Jul 14, 2003 | 10:03 PM
Mr.Whitey's Avatar
http://www.geocities.com/MotorCity/6647/ta93/knock.htm
http://www.charm.net/~mchaney/knock.gif
I don't plan on doing either but here is how you would do it. My understanding is that the 93's really don't need it.
Old Jul 14, 2003 | 10:04 PM
There's an excellent database of mod instructions on ProjectTransAM.com . Look on the list on the left side, under "Install Guides". You can also find another good database on Brent Franker's website.
Just to clarify... I'm pretty sure the 93-95's use the same knock sensor, and have a similar sensitivity. What is different in the 93, as pointed out above is the absence of the knock module, forcing people to find other ways to overcome false knock.
Before you jump into "desensitizing" the sensor, remember that you are reducing sensitivity to both "real" knock and "false" knock, and reducing the level of protection that the knock sensor offers.
Old Jul 14, 2003 | 10:10 PM
Got-LT1's Avatar
I stand corrected, thank you for explaing it Injueer.
Old Jul 14, 2003 | 10:38 PM
93LT's Avatar
thank you guys very much.
Old Jul 15, 2003 | 12:23 AM
93LT's Avatar
just did it, and i think this solved my bogging problem under 2k. i really hope so. drove it for like 10 min, and that is usually long enough. guess i'll see tomorrow in the heat of the day.
MadMav
May 25, 2015 09:35 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
