Small black device on the passengers side of LT1 intake... what is it?
Old Jul 14, 2003 | 04:14 PM
Jesse_Boyer's Avatar
I'm missing a vacuum line to whatever that piece is... so what is it? Also, where does that vacuum line go to? I've already got one hooked up to that piece and it runs to the hose near the fuel lines. So, where's the other one go?
Jesse (kinda forgot things after taking it apart 7 months ago )
Old Jul 14, 2003 | 04:21 PM
Found out what it is: EVAP canister purge solenoid valve. Next question, if I don't have an evap. canister, can I delete this? I'm not sure if I actually replaced it when I built the car.
Therefore, can I just remove it and plug the throttle-body?
Jesse
Old Jul 14, 2003 | 04:37 PM
If you don't have a canister, there is little need for the solenoid. Cap the tube on the throttle body. Your OBD-I computer will probably not complain about it, but if it does, you can have it programmed out. FYI, having the EVAP (or even EGR) does not hurt performance any.
Old Jul 14, 2003 | 04:40 PM
Mizz96Z28's Avatar
Is it the doohickey with the red/blue plug, and has 2 nipples ( I said nipples) facing the firewall? If so one is suppose to be a vent I believe and the other is the vacuuma line for the fuel pressure regulator I think (going from memory) but them again I dunno if my 96 is different from your 94 in that area
Myles
Old Jul 14, 2003 | 04:51 PM
96z's Avatar
96z
Myles
Ive been wondering this since both of mine are open and I have a code related to this. Does the fuel regulator vacuume line go to one of these?
Old Jul 14, 2003 | 04:55 PM
wicked_95z's Avatar
Your fuel pressure regulator vaccum line should go to the bottom intake fitting on the passenger side of the intake. Right below the vaccum line for you a/c.
Old Jul 14, 2003 | 06:12 PM
96z's Avatar
96z
Ok, thanks thats what I thought.
Old Jul 15, 2003 | 12:05 AM
Mtrhds94Z's Avatar
Radiator hold down bracket should have a sticker with vacuum hose routing on it..
Old Jul 15, 2003 | 12:09 AM
thewinner's Avatar
what exactly does the EVAP do? Is it really needed? shoebox?
Itd be kinda nice to get rid of it off the side of the intake, clean up the engine a little more.
Old Jul 15, 2003 | 09:17 AM
hmm... I don't think I have a vac line running to the AC... Where does the line connect to the AC? Anybody have a picture of that?
Old Jul 15, 2003 | 12:47 PM
Mtrhds94Z's Avatar
It begins right on the intake manifold, in that same area, and it goes into a wiring harness, and then to the dash heater/AC controls..
That's the hissing that you hear when changing positions...
Old Jul 15, 2003 | 01:16 PM
turbo_Z's Avatar
heres a pic of the evap system on a 96-97. here for a 93-95.
now since we are talkin about EVAP(kinda) what is the need for that extra round shaped device on the 96-97?
Old Jul 15, 2003 | 03:36 PM
It pulls gasoline vapors from the gas tank and feeds them to the engine to be burned. A correctly operating EVAP system does not hurt performance and reduces ozone.
Old Jul 15, 2003 | 03:37 PM
Where the vacuum line goes.
Old Jul 15, 2003 | 03:39 PM
The "round thing" is a vacuum switch that the OBD-II system uses as a watch dog on the EVAP system. It tells the pcm if the system is acutally working when it is supposed to.
Jul 4, 2005 05:00 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Bando
Oct 7, 2002 07:36 PM
Roshambo
Sep 4, 2002 11:25 AM
blue89iroc
Jul 26, 2002 04:56 PM
