Should I put a Melling stock Oil Pump or get another HV?
Old Jul 14, 2003 | 12:49 PM
zhevy-1's Avatar
I'm doing some work on my 383 stroker after 10k miles. It has a Melling HV Oil Pump, and a Canton 7qts oil pan. I'm replacing a piston, re-ringing the motor, replacing a broken valve and I'm debating whether I should by another Melling HV oil pump, or get a stock Melling instead.
I definitely want to put a new oil pump. I did have some issues related to oil psi being unstable at one point.
Thoughts?!
-Goose
Old Jul 14, 2003 | 01:14 PM
mc63's Avatar
Actually, the stock pump supplies our engines with plenty of oil, even a 383.
Old Jul 14, 2003 | 01:42 PM
zhevy-1's Avatar
So...I shouldn't have a problem putting a stock one to work with my Canton 7qts oil pan?
Old Jul 14, 2003 | 03:09 PM
96z's Avatar
96z
A stock one should be ok. A melling stock replacement would be the next step up.
Old Jul 15, 2003 | 03:30 AM
ZBLKHELLRZR's Avatar
Question
zhevy-1 I'm doing some replacing on my 396 too. Do you happen to know if that canton oil pan will clear flp's? Do you have anything in the pan like, baffle's, windage tray, scaper etc? My Morosso 7qt came with nothing! I need a real oil pan before putting it back together.
Thanks!
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
MJ_Z28
Aug 8, 2002 09:07 PM
