Fuel map,Timing table.....
streetbad
07-12-2003, 11:11 AM
Tuner guy is coming over. He asked me to get a timing table. Please help. I am putting in 30 lb svo's. Cam is xe218/230@112. Heads are 260/197. Long tube headers,stock short block. .026 head gasket, 93 octane fuel,M6. Is stock fuel pressure 43 or 43.5? Is ford 39 or 39.5? Thank you. Tim
Highlander
07-15-2003, 10:04 PM
What exactly do you want?
streetbad
07-16-2003, 10:02 PM
spark map or spark calibration
Highlander
07-16-2003, 11:13 PM
Well... you have to make some runs and up until you get ping and then drop 1º and you will be ok...
Dan K
07-17-2003, 12:01 AM
With your combo, the stock map will work fine to start. You'll need to tweak the wot timing though.
As far as part throttle you could probably add a degree or 2 here and there. It's just something you're going to have to experiment with.
Highlander
07-17-2003, 09:36 AM
My point... after you get to the verge of pinging drop back a degree or 2 because just before pinging its too much timing and many times it doesn't like it...
