SD LT1 tuners - PE vs RPM
Old Jul 11, 2003 | 11:29 AM
PLANT PROTECTION's Avatar
For anyone who tunes their 92-93 speed density LT1, what does your %Change to A/F ratio vs. RPM look like? Going by the formula in the help, which I understand prob isn't close at all, it shows a PE A/F ratio of almost 19:1. Just wondering how your graph looks after being tuned.
Old Jul 11, 2003 | 11:20 PM
Dan K's Avatar
It depends on too much for you to get much info from what others have done for their tunes.
My buddies 396 was 12.3:1 on the wideband and I think the pe vs. rpm was increaseing from 5 to 7 as rpm increases. This was with a Lucas 42lb injector and a constant of 42.5.
Old Jul 12, 2003 | 08:56 PM
This is how my stock table looks:
RPM %Change
400 - 11.7
800 - 11.7
1200 - 11.7
1600 - 11.7
2000 - 41.4
2400 - 35.9
2800 - (-17.2)
3200 - (-29.7)
3600 - (-14.1)
4000 - (-1.6)
4500 - (-6.3)
5000 - 4.7
5500 - (-6.3)
6000 - (-8.6)
6500 - 7.0
7000 - 3.9
7500 - 7.8
Why is there such a drastic change in numbers while in reality, the change in fueling is more linear. Any thoughts?
Old Jul 13, 2003 | 10:39 AM
rskrause's Avatar
Moderator
The numbers aren't derived from a formula. They are empirical numbers derived from real world measurements. Data trumps theory everytime. Why do you say "in reality, the change in fueling is more linear"?. I am not sure what you mean by this.
Rich Krause
Old Jul 13, 2003 | 01:36 PM
The formula I was refering to was in the tunercat help file:
"The resulting air / fuel ratio can be calculated as follows:
PE AFR = 14.7 / (1 + %Change vs Cool/100 + %Change vs RPM/100)"
My comment did come out bad. Assuming the VE tables are dead on, I figured the amount of fuel added in PE mode should be close at all RPM, where as the stock table is indicating that there is a drastic change in the amount of fuel delivered at 2400rpm compared to 400rpm higher. Is my thinking correct?
DirtyDaveW
Dec 1, 2016 05:37 PM
edman
Jan 22, 2015 02:45 PM
Jul 4, 2005 05:00 PM
tubby
Oct 13, 2003 09:16 AM
centric
Aug 15, 2002 09:04 PM
