Found this box under dash.. alarm?
Old Jul 4, 2003 | 03:53 PM
madwolf's Avatar
Arrow Found this box under dash.. alarm?
Yesterday I was working on the '93 I just bought and I found these two devices which I'm not too sure about.
One of them is small and has "shock sensor" written on it. I'm assuming this is for an alarm. The battery was dying, but I saw it blink once. The other box is a bigger one and has Q-Start written on it.Could this be a remote start or something like that?
The previous owner didn't even know there was an alarm on this car so I'm not sure if I should keep this stuff and try to find a remote for it, or should I remove it.
Pictures here:
Pic 1
Pic 2
Thanks!
Old Jul 4, 2003 | 04:16 PM
PGR's Avatar
PGR
Aftermarket alarm. May have been installed by the dealer. Some dealers do this automatically, then add a bundle to the sticker price ($500 or more). You can buy something similar for about $100.
Unless you have the remotes to use it, remove it. Mine would set and trigger itself in the middle of the night - the routine got old very quick. Be carefull, make sure you reconnect any breaks in the factory wiring, if any.
A buddy bought a used '94 from a dealer, and later had to do some work on the car. He disconnected the battery during the work, and afterwards, the car wouldn't start. Turns out the car had an aftermarket alarm with an ignition cut out.
Old Jul 4, 2003 | 05:04 PM
Ryan94ZA4's Avatar
The Q start is an Avital (Clifford) remote start. The 2nd picture is of the shock sensor for the alarm. Avital is pretty decent stuff and it would be worth the 20 bucks to buy a remote; you'll have an alarm and remote start.
ryan
Old Jul 4, 2003 | 05:17 PM
madwolf's Avatar
ryan
Thanks Ryan.
Where would I find a remote for it and how do I match it to the current setup?
Old Jul 4, 2003 | 05:20 PM
NineSevenWS6's Avatar
Call up DEI ( www.dei.com ), give them any info you can find/read from the brain. Tell them you need a remote and installation/user guides. With the remote/guides, youll be able to program the new remote(s) fairly easily...
Old Jul 4, 2003 | 05:37 PM
Ryan94ZA4's Avatar
Nine Seven is right.
Be prepared to wear yourself out; it's been a while since I've reprogrammed an Avital remote but I do remember how to get into programming mode I think: Door open, turn key on then off 5 times leave key on 5th time. Flip the valet switch on and off 13 times. Sheesh.
Ryan
Heathen1
Jan 2, 2016 04:27 PM
cmsmith
Apr 11, 2015 09:37 PM
94Z28LS1toLT1
Jan 17, 2015 08:29 PM
kandied91z
Aug 6, 2002 01:18 AM
HuJass
18
Jun 24, 2002 09:19 PM
