Question about NGK's?
Old Jun 27, 2003 | 08:52 AM
RealQuick's Avatar
I am gonna be installing my NGK TR6's and I am not sure how much to gap them. Any one know? Thanks.
Old Jun 27, 2003 | 09:10 AM
Dave Feerst's Avatar
.050 on all plugs unless you have added boost or spray or changed your compression raito.
Old Jun 27, 2003 | 09:16 AM
Fuels94TA's Avatar
For TR6 which is a good plug on the bottle is gapped at .035- .040
Vinny
Old Jun 27, 2003 | 09:37 AM
RealQuick's Avatar
Hmmm. 2 different answers. Anyone else want to chime in?
Old Jun 27, 2003 | 10:56 AM
BUBBA's Avatar
Why TR6 and not TR55 at .050?
Old Jun 27, 2003 | 11:01 AM
jeremyferguson's Avatar
On spray I've always been told TR6 with .035-.040. You could also check in at N2O tech if you are spraying......
Old Jun 27, 2003 | 11:05 AM
RealQuick's Avatar
Not spraying for now, but I decided NGK TR6's just to try out.
Old Jun 27, 2003 | 11:37 AM
Don 97 SS's Avatar
You'll get several opinions on this,so don't expect just one right answer. I gapped my Tr5s at .035 FWIW.
Old Jun 27, 2003 | 11:47 AM
96speed's Avatar
The TR5s and TR55s are the same plug. The TR5 is pre-gapped at .05, and the TR55 is gapped at .035-.04 I *think*. The TR6 is a step colder plug that is recommended for nitrous.
Stock replacement is a TR55 at .050". You will probably notice little difference between a TR55, 5, & 6 if your car is healthy.
I have had knock retard, and my TR55s always came out white (hot). I swapped to the TR6s, gapped them .040" and they "wore" nice and brown. However, I still saw knock retard (real).
Ryan
Old Jun 27, 2003 | 09:58 PM
Like I said the first time .050 if you are not spraying or boosting. The bigger the better(to a point), as long as your coil can handle it. Closing the gap just makes it easier for the spark to jump the gap when pressure is high (like when you are boosting or spraying. but closing the gap also slows flame travel. If you havent changed cylander pressure use OEM reccomendaion of .050, no matter what plug you have.
Jazsun
Dec 29, 2014 12:14 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
guyomatic
Sep 11, 2002 02:11 AM
