what do these wires go to
Old Jun 26, 2003 | 11:01 PM
sc1twntrbo's Avatar
i took out ny console today and taped to my cig lighter wires is another set of wires. the set ir a 6 pin harness with 5 pins being used. the wires on the back side are mostly brown and black (i belive ) and the same with whitee stripes. what was this used for
btw i have a 97 ta
Old Jun 27, 2003 | 12:06 AM
fbird95's Avatar
Not sure about the 6 prong connector, maybe for automatic, if you have a manual. I know in my car there is a coiled up set of wires, which is the aditional power connector mentioned in the owners manual for the knock out in the console. Not that it helps you out much. I'll have to see if i have the same thing in my car.
Old Jun 27, 2003 | 08:17 AM
sc1twntrbo's Avatar
i got a 6 speed and it is coiled up and taped to another wire
Old Jun 27, 2003 | 08:22 AM
jeremyferguson's Avatar
could also be for the convertible top switch. The wires going to my switch are the colors you mentioned......
Old Jun 27, 2003 | 08:28 AM
z28jaz's Avatar
Sounds like the switch for the convertible top.
Old Jun 27, 2003 | 05:54 PM
sc1twntrbo's Avatar
iss there a way i could use them to my advantage since i dont have a convertable. like a switch for something else were would the other end be
Old Jun 29, 2003 | 12:55 AM
fbird95's Avatar
I suppose you could tap power and ground from them if you really wanted to. Not sure which colors you would use though.
surreybrad
Apr 22, 2015 06:40 AM
EdgarArmada
Apr 18, 2015 05:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Ryabut98
Sep 3, 2002 11:45 PM
kandied91z
Aug 6, 2002 01:18 AM
