EGR gaskets?
Old Jun 24, 2003 | 10:44 PM
PatriotTA's Avatar
EGR gaskets?
When blocking the EGR do you need new gaskets for the 2 plates on the intake? Or can you just pull off the old gaskets and use soem RTV? What RTV would you reccomend (black or copper)?
Old Jun 24, 2003 | 10:48 PM
speedmiser's Avatar
The black should work fine. I wouldn't bother with the OEM gaskets.
Old Jun 25, 2003 | 05:03 AM
revtime's Avatar
I used copper on mine.
I had an EGR blockoff plate that I bought from GM but then I ran into the OTHER hole in the manifold so I got some hi temp gasket material and took the metal hose out of its bracket, cut me a gasket and used the bracket and my gasket as my blockoff.
Old Jun 25, 2003 | 05:28 AM
av8er's Avatar
I didn't see anything wrong with using the stock gasket unless it is damaged.
JeffA
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
pepon214tx
Sep 20, 2015 04:48 PM
Pwilson59
Sep 3, 2015 08:47 PM
