Opinions before car gets worked on
Old Jun 23, 2003 | 05:08 PM
Wraith's Avatar
Question Opinions before car gets worked on
Ok, so the car is getting a new clutch, water pump, radiator, intake manifold fix, plugs, wires and head gaskets for sure. My question is to get a new opti and timing set or not?
The car has 98K miles and my only car right now. It is a '96, so it has the newer opti, but since it is all coming apart would it be worth the investment now to get the opti and timing set replaced?
thanks.
Old Jun 23, 2003 | 05:48 PM
93midnightta's Avatar
if you have the money do it now while all the parts are already off the engine. the vented opti is only about $230 from the big three direct guys. do searches for dal, jason and i forget the third guys name.
Old Jun 23, 2003 | 05:55 PM
KCFormula's Avatar
If it is the stock opti then I would just for insurance. But I doubt its stock if it looks clean there should be no reason to replace it. (as long as the shop doesnt deuche it with water when taking your H20 pump off. )
Old Jun 23, 2003 | 06:38 PM
Wraith's Avatar
Thanks for the replies. Any thoughts about the timing set?
fpete1992
Dec 11, 2014 03:51 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
mr28
Nov 23, 2014 11:11 AM
Snoman73
Nov 17, 2014 07:22 PM
