NEED HELP! Cross-Threaded Header Bolt -- What tap do I use
Old Jun 20, 2003 | 05:53 PM
G's Z28-LT1's Avatar
Anyone know what tap I need to clean the threads in the head the the header bolt screws into? Also, what Heli-Coil would I use if I can't save the threads.
Thanks.
Old Jun 20, 2003 | 06:43 PM
FastZinTennessee's Avatar
3/8 x 16 thread.
Old Jun 20, 2003 | 07:01 PM
94ZVert's Avatar
Just a thought... to Heli-Coil the head you'll probably have to take it off. What I ended up doing was using a slightly longer bolt (1X3/8 I believe). Anyway, it was long enough to catch the rest of the threads and so it worked perfectly. You might want to try that first. Good luck.
Old Jun 21, 2003 | 12:35 PM
Thank you both for the help. What I'll do is try to chase the threads; if that doesn't work I'll try the longer bolt. If all else fails, I'll p&p the heads.
Thanks again.
Old Jun 21, 2003 | 12:44 PM
Camaro_SS/R's Avatar
Hopefully you can chase the thread or just use a longer header bolt. The longer bolt usually work.
Heli-coil - as long as you have enough room to drill the hole you won't need to pull the head. You may also try to cut the bit shorter to help.
the simplest thing something cost a big problem, hopefully it will be a quick fix.
good luck
Victor Lamb
Aug 26, 2017 02:52 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
BigWil
Mar 29, 2015 12:24 PM
maybe2fast
Mar 16, 2015 09:45 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
