Cloye's double-timing?
Old Jun 18, 2003 | 10:08 PM
FacelessZ's Avatar
Anyone using Cloye's double-timing chain? Is it a decent set-up?
Old Jun 18, 2003 | 10:51 PM
kirschman's Avatar
I run it and love it. Whole lot cheaper than any HD LT1 t/c. Its stronger (IMO) than the extreme duty GM set. Plus u get the option to advance or retard the cam. Simple install also. You just have to run an electric w/p and delete the CPS on the OBDII cars. No biggie, just a reprogram. Cloyes cost me bout 80 bucks
Old Jun 18, 2003 | 11:18 PM
FacelessZ's Avatar
$80 where? I was told it's at summittracing.com but can't find it...
Thanks again
Old Jun 18, 2003 | 11:24 PM
RealQuick's Avatar
CSI Electric Water Pump (Jegs) 170-901LT1
Old Jun 19, 2003 | 02:47 PM
FacelessZ's Avatar
Electric water pump and its relevance to a Cloyes timing chain?
Old Jun 19, 2003 | 02:53 PM
GetaZforgetGT's Avatar
The stock water pump is driven by the stock timing chain (maybe an oversimplified expanation). With the cloyes in place that option is not there and an electric water pump must be used.
Pro: electric W.P. frees up a few ponies
Con: life span of electric W.P. has been questioned.
Under normal conditions you won't know the electric has failed until you see the temp gauge go up.
I'm sure other will elaborate more.
Old Jun 19, 2003 | 05:16 PM
FacelessZ's Avatar
Thank you very much for that insight. I'll definitely look into it a bit more...
Old Jun 20, 2003 | 07:00 AM
IDOXLR8's Avatar
The Cloyes part number is 9-3145. Also you may want to look at the new Lunati chain as an alternate option (see new Summit catalog).
Old Jun 20, 2003 | 11:55 AM
Mr. Z28 73/97's Avatar
I got the Rollmaster double roller timing set both gears are billet steel and it been tested to 1000hp and you can adv/ret cam +/_ 8*.
It was designed originally for the factory roller blocks it was $90 from scoggin - dickey parts center.
KamikaZ28
May 28, 2015 12:45 AM
95LT1Z28
Aug 25, 2004 12:53 AM
atljar
Mar 14, 2003 03:24 PM
brain
Jan 27, 2003 07:29 AM
