Which setting do I put the cloyes double roller crank sprocket on???
Old Apr 14, 2003 | 05:16 PM
95LT1Z28's Avatar
Question Which setting do I put the cloyes double roller crank sprocket on???
I am in the middle of my cam swap right now and I am converting to the cloyes double roller setup. The back of the box says the O position for o.e.m. setting, but the only setting that will work is the square one which says for 2 degrees retarded. Do I use the stock keyway in the crank or do I just install the cloyes to use the square setting since that is the only one that will fit the stock key???
Thanks,
Jeff
Old Apr 14, 2003 | 07:11 PM
Dr.Mudge's Avatar
Easy, look at your stock gears and compare the two. I believe the proper non retard/advanced selection is simply the square "peg hole" just like stock, but compare the gears by the dots - and then look at the pegs to see which to use, then mark it if you like.
Old Apr 14, 2003 | 08:04 PM
95LT1Z28's Avatar
Unhappy
Dr. Mudge, forgive my ignorance but what do you mean by "peg hole"? The hole for the cam dowel? I tried calling summit tech and they were clueless. Each position looks the same whether it be advanced, retarded or normal. Do I just use the stock square key position regardless since that is the only one that will fit?
Thanks again!
Jeff
Old Apr 14, 2003 | 11:14 PM
Dr.Mudge's Avatar
As best as I can recall, I am using the square peg - and it would make sense wouldn't it.
Look at the timing mark (dimple) on each gear, put them at 6/12 so that they face each other, and look on the crank gears both and look at the peg-hole locations for both, ensuring again that the timing marks are the same on both timing sets when layed out on your table/bench.
So, as far as the cam gear the only thing you need to look at is the dimple, lay out both timing sets just as if they were on your car, line them up and both and it should be pretty obvious which to use. Make sense?
Old Apr 15, 2003 | 12:15 AM
Jason Dove's Avatar
Use the square mark, and they line up 12 and 12, not 6 and 12.
I have no idea why... but 3 cars so far it's been 12 and 12 with the Cloyes.
Old Aug 24, 2004 | 06:41 PM
blown383's Avatar
Re: Which setting do I put the cloyes double roller crank sprocket on???
I was told that most aftermarket cams have 4 degrees retard ground into them...so if you go with the square which is 4 dregrees retarded for a total iof 8 degrees retard?
Im still trying to figure this out.
-B
Old Aug 24, 2004 | 11:50 PM
The circular mark on the Cloyes crank gear matches the one on the stock gear.
It was my understanding that the square is 4° retarded and the triangle is 4° advanced.
The crank gear should fit on the key in any of those positions.
Old Aug 25, 2004 | 12:53 AM
atljar's Avatar
Ditto what shoe said. Mine fit fine.
DirtyDaveW
Dec 1, 2016 05:37 PM
chuyz28
Jan 15, 2015 04:14 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
97 RedSS
Jun 10, 2003 07:58 PM
